What is done to make the 94's CAS work with the 92's harness? Or is it the other way around? convert the '94 engine to the '92's sensor (if even possible) Does the 94 cam even have the slot to drive the sensor? I have both engines sitting side by side on the ground... and the only difference I can see is the wires coming out of the timing cover on the 94, and the module on the end of the head for the 92.
Man, IIRC, *doubtful* I would've sworn I read SOMEWHERE that it's just a matter of getting the correct wire back to the old harness..
