1992 $ 20,999.00
572 + HP 1992 Dodge Stealth Twin Turbo , 6G72TT, Dark Green Super Car
$20,999.00 Or Best Offer! Must Sell.
119 Pictures and 9 Videos Available (491 MB download) :
No need to subscribe to Dropbox, Click Continue To View under the subscription fields to download direct. Click Download Direct on the link For Videos, Pictures and other items included with the sale.
https://www.dropbox.com/s/6rcnix6dp1...ealth.zip?dl=0
Temporary Craigslist ad w/ pics: https://detroit.craigslist.org/okl/cto/6181207484.html
For sale in Detroit, Michigan Metro Area zip 48309. Title In Hand. Second Owner
Original Miles on Chassis: 84,063
Miles on New Engine Block and all Upgrades : 693.3
(Odometer indicates original miles and engine break-in miles on trip)
Interior Condition: Immaculate 9/10- Still looks and Smells New! Exterior 8/10
Always garage kept, no accidents.
VIN : JB3XE74C7NY060980
As of 1/24/2017 - Car was professionally checked and serviced to prep for sale.
All fluids have been replaced, brand new Injector Dynamics 725CC Injectors and wiring harness installed. (6 x Blitz 720cc injectors included with sale of car incase you can clean and revive them), new NGK Iridium BKR7EIX spark plugs gapped at 0.25 (2 new surplus replacements included) , new MSD Plug wire set installed and Engine Compression Test confirmed as C1-151 C2-154 C3-151 C4-138 C5-148 C6-152. (High - Low Range = 158-115psi for Turbo Cars)
List of Modifications Professionally Installed
GTPRO 368Sx Turbos [ported and clipped 15 degrees] [TD05 Compressor / TD04 Exhaust]
GTPro 368SX Aluminum FMIC and InterCooler Pipes
Injector Dynamics 725cc Injectors and custom wiring harness
Custom Dual Feed Fuel System
Supra Fuel Pump Hot Wired
TIAL Blow Off Valve
Custom Dual Filter Intake (speed density)
AEM Stand Alone Engine Management System (EMS)
AEM 3.5bar MAP Sensor
AEM UEGO Single Channel WideBand 02 Sensor
AEM Air Fuel UEGO Display Gauge
Dynamic Racing 02 Eliminators
Dynamic Racing Ported Manifolds
Dynamic Racing Stage 3 Heads
Dynamic Racing Hi Rev Kit
APEX'i Oil Pressure Gauge (60mm Electronic)
APEX'i Coolant Temp Gauge (60mm Electronic)
APEX'i Fuel Pressure Gauge (60mm Electronic)
APEX'i EGT Gauge (60mm Electronic)
APEX'i Boost Gauge (60mm Electronic)
APEX'i Actuator Valve Controller Type-R (AVCR)
ATR Full Exhaust System with Straight Pipe
Greddy Turbo Timer
Cusco Rear Strut
RSR Springs
K-Sport Suspension
Carbon Fiber Hood, Green
99 Front End Fascia and Headlights
Race Pedals
3SX Aluminum Radiator & Hi Flow fans
3SX Aluminum Crank Pulley
3SX Stainless Steel Braided Brake Lines
Greddy Oil Catch Tank
Kevlar Timing Belt & New 60k Service
Custom 6 point Grounding Kit
Custom Steel braided Turbo coolant and oil lines
Solid Steel Motor Mounts
RPS Lightened Flywheel
HorsePowerFreaks 700+hp Race Clutch Kit
Racing Oil Pan
MSD 8.5mm Wires
PST - Carbon Fiber 1 piece Drive Shaft
300M Hardened Output Shaft 18 spine conversion to 25 spline
Oddysee PC 680 Extreme Race Battery (New)
Transmission - All internals cleaned, rebuilt by TRE
Short Shifter
New Volk Racing Gram Lights T57 RC Wheels (New, no scratches)
ProRacer Lug Nut Set Gunmetal
New Falken 275/35 ZR18 High Performance 18x9.5 tires all around (full original tire tread- never saw more than a few miles on any road due to the duration of the project/storage). The original break in miles as indicated on odometer were done using the stock wheels/tires. It was only after the initial tune did I have the new wheel/tires installed and put up on stands.
** Note : Transmission Refill hole cracked - requires swap out or new internals replaced in new housing. Only housing is needed, all transmission internals are new. New Injectors need AEM Re-Tune - Call to discuss details.
-All receipts and manuals of original and modification parts and records of service
-Includes CDROMs of All 3S Manuals
-Includes all Trunk Space Plastic Trim in excellent condition (uninstalled from vehicle but included with sale)
-Includes miscellaneous hardware, equipment, oil+filter, box of surplus screws, bolts, fuses, ties, fittings, hose, spark plugs, injectors, etc accumulated over the years.
-Car retains original radio. Both radio and steering wheel buttons work excellent. Speakers still in excellent condition. Car is wired for subwoofer placement in trunk (wires laid and fuse upfront near battery)
-Electric Windows work great
-Heat is excellent, the A/C does work but needs to be recharged and perhaps for peace of mind checked for leaks. The A/C on the car was not typically used much in general.
-New Aftermarket Cobra Car Alarm is installed and remote startup functionality was verified. I decided to disconnect the alarm system from the battery to simplify servicing and error checking car codes. (sometimes Aftermarket alarm systems play games with the electrical systems which is what I wanted to avoid . You can connect it and use it as intended as it works just fine. Key Fob and second Fob included with all original manuals.
- Two car keys included. One Original Dodge Stealth Key and one replacement key copy.
-Had the car cleaned and repainted dark green, paint job is in excellent condition with exception of minor scratches that come with normal wear and tear.
-Front end was fitted with 99 Fascia and headlights - however due to cold weather in storage and the intercooler fitting, the left side has popped out about 2 inches. This is a quick fix - finished fit is very nice and tight with the headlights. See pics.
-Alternator checks out good - see video test
-Calibration map file for the AEM is loaded on the ECU, however an update is needed to accommodate the Injector Dynamics 725CC injectors. the .cal map file can be provided by email as a backup or baseline for future tuning. Tuning was professionally done by Horsepower Freaks / Torque Freaks. Have dyno sheet indicating 14psi at approximately 451 HP. I did not have the time or resources to push the numbers higher, but the car's build should easily allow you into the 20+psi range or more. (451hp x 27% drive loss = 121.77 + 451 = 572.77 HP crank.
-Custom Car Cover Included
-Car sold as is with everything in this add included unless other arrangements are made.
$20,999.00 OBO.
