Here's most of the information you guys need:
You can go with whatever 6G72 rods you want. I'd either go with the 3SX rods or the guy on here that makes them for $599 iirc. Unless you have the money to spend, Ray's custom rods aren't necessary. The pistons are though and so is the machine work and balancing. I would go with modified stock piston pins or Ray's custom tooled steel pins.
I believe the machine work for the crank was $900 and the balancing was a little over $600. I'd have to go back and look at my receipt but I thought altogether it was about $1500-$1600 for the machine work and balancing. Edit: I looked at my PMs and the machine work and balancing was $1550 together.
