Went to install my cams during a loooong rebuild and found them rusted.
It's a stock 92 Stealth SOHC.
I am now looking at cam choices.
1st choice is to get a set of used cams and run the engine another year while I build a DOHC or even a TT.
2nd choice is new replacement or slightly better cams.
Nobody has Stealths around here so I am looking for alternative Junkyard engines to get a replacement cam.
There are thousands of 3.0 Chryslers BUT the HP specs for the Stealth/Mitsu is 164hp and the Chrysler 3.0 is 141hp.
Parts stores list the cam as being the same.
Is the HP drop from the different Intake/Exhaust manifolds on the Chrysler or is the cam also part of the HP drop?
Is there a better year cam to get that will swap in? I have seen 2002 Eclipse's with the 3.0's but parts books say no can do the swap.
Any input would be great.
