Results 1 to 7 of 7
Thread: C3 Custom Climate Control
    Introducing Moliva3D C3 (Custom Climate Control)
    What is C3? A number of things
    1. C3 is a modern facelift to the dated and often failing climate controls. The all new interface is a colorful fully digital LCD display with a clean intuitive design of our own making.
    2. C3 is the final solution to consolidating all your diagnostic wants into one convenient location for the 3000GT and Dodge stealth. It's full potential is unlocked using the Blackstealth LCDBC controller. The extensive functionality of the LCDBC is ported to the C3 and enhanced with real time visual data.
    3. C3 is convenience. The C3 is 100% plug and play. No cut wires, no splicing, just plug it in and enjoy.
    4. C3 is clean. Tired of cumbersome gauge pods? Having to find places to mount equipment? Is your car starting to look like the interior of Paul Walker's Fast and the Furious Eclipse? Take advantage of all the functionality of gauges without sacrificing the factory interior.
    Check out more details at http://moliva3d.com/product/c3-custom-climate-control/
    Check out technical details at Support – Moliva3D
    Demo Video
    https://player.vimeo.com/video/211226438
  2. The Following 3 Users Say Thank You to 3krazygt For This Useful Post:
  3. #2
    Rochester Hills, Mi
    I guess I'll ask here. Maybe others are having the same issue. Mine will only communicate with the LCDBC when the LCDBC is in setup mode. (Press and hold the encoder during power on) Is there a setting I'm missing? I set the Datalog setting to "TFT and the Pass through is set at 57600. I've tried a few other settings but nothing seems to work.
    95 Base 3k: 6G74/TT/AWD conversion
  4. #3
    Oct 2011
    Sundsvall, Sweden
    I've been looking at the Moliva C3 myself. Please report back on how this unit works you Uniuno and if this issue gets resolved.
  5. #4
    Uniuno: Which LCDBC software version are you using?
  6. #5
    Rochester Hills, Mi
    It's running 4.15. Before I didn't have the option for TFT.
  7. #6
    LCD Version 4.16 fixed the C3 climate bug.
    I'll go ahead and do the same bug fix for the 2x16 OLED version too.
    By the way, I haven't told the C3 makers that now there's a 4x20 OLED version too, they would have to make software changes if they want to support the extra characters.
    http://lcdbc.xp3.biz/updates/UPDATE416.zip
  8. #7
    Rochester Hills, Mi
    That worked! It connected right up. Thanks!
