Results 1 to 10 of 14
Thread: BlackStealth LCD controller - Boost Controller Issues
    Never finishes any verified
    Wake Forest, NC
    I didn't want to clog up the already long post so figured I would create a new one. Has anyone had issue with the Boost Controller portion of the BSLCD?
    So I have everything hooked up and working fine. GM Sensor logging boost pressure is working fine, MAC valve all hooked up and tested fine, Trying to set the boost controller and not matter what i do it always overboots, like it is not doing anything at all.
    I originally had the Duty Cycle set to 14 thinking it was boost PSI not Duty Cycle percentage which honestly I still don't understand why it's not just set a psi and go with it, but whatever. Took it for a spin and hit 18psi overboost warning at like 40% throttle!! WTF! Ok so read the manual and found it was a duty cycle percentage and not a PSI setting like I though, but then realized at 14% I should not have been anywhere close to 18PSI of boost. So took it back out and played with the settings, set it to 0% and overboosted, set it to 100% and overboosted.... OK so WTF both ends of the spectrum and I'm still overboosting, how the hell do you set this thing?!?!?
    Luckily even hitting 18psi I was not knocking and fuel was still good at like 10.5AFR as I have not really tuned it. Trying to get it set at 12psi stock to get trims and such dialed in before I start adding boost. Since I can't get the boost controller portion working I'm sort of SOL right now since the 13G's spin up sop damn fast...LOL All of the other Boost related setting are still default as far as I know. I only have the boost alarm set at 14 psi.
    I also noticed randomly that when the car is on I can hear the mac valve randomly clicking under the hook off/on. Not sure if it is related or normal.
    Anyone have a clue?
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Any way for you to hook up an analog meter or a scope to the solenoid wiring?
    Medford OR
    Sounds like you have it plumbed wrong... You should have wastegate boost with the solenoid unplugged or set to zero duty cycle.
    Wake Forest, NC
    Only have a Digital meter here. No scope.
    I have it plumed as left port vacuum in, right out to wastegates, center is the breather plug thingy. Basically like this:
    The BSLCD manual does not have a hookup diagram but I'm guessing now that I should have it hooked up as:
    Guessing it all depends on if the BSLCD energizes it to stop boost, or is stays energized until it needs to cut boost and I'm not sure which way it runs.
    I think you have it plumbed wrong, it doesn't match to the picture I have on the manual.
    See page 7 for boost solenoid installation:
    http://lcdbc.xp3.biz/InstallationEBC.pdf
    Next , go verify these settings:
    "PSI Start=1psi"
    "PSI End=2psi"
    If those advanced settings are incorrectly set, you could be running 100% duty cycle, or other weird overboost/pulsating effects. Those settings are for cheating, ie. run 100% duty cycle for faster turbo spool up temporarily before you reach your target boost. Most people don't understand this concept, so it's best to leave them at default (essentially off).
    Also when you hit alarm boost pressure (overboost), it will set duty cycle=0% for 5 seconds.
    Greg, I'm gonna guess - once you've got it plumbed correctly using Antero's guidelines - you could set duty cycle around 34-35 and be in the 12-13 psi range.
    Your FMIC may bump that a bit, though; I'm running 13Cs with DSM SMICs, and setting duty cycle around 40, I can bump 15 PSI.
    A little goes a long way.
    Like I say though, your front mount will likely allow you hit a higher number easier than the stock ICs; swapping my stockers for the DSMs without adjusting duty cycle put me about 2PSI higher than I intended before adjusting it back down.
    Wake Forest, NC
    "PSI Start=1psi"
    "PSI End=2psi"
    OK, yeah I have the manual with all of the settings in it. Never knew this install manual existed. So yeah I have it hooked up wrong. Will get that fixed tomorrow after work hopefully. May be able to get a quick test drive in. Not sure what the weather will be like when i get home though.
    Will let everyone know. Thanks!
    Wake Forest, NC
    OK, So I was wrong again. I checked the MAC valve when I got home and I do have it plumbed correctly. Center goes to Y-pipe and the left port goes to wastegates. Exactly like shown in the manual. So not sure what I need to look at now.
    Here were the last settings I used in the Boost controller menu. Pretty much all blank.
    PSI Start 1.0
    PSI End 2.0
    Aux Duty 0.0
    Duty Cycle Temp - Default
    Alarm Boost 15
    Duty Cycle 0.0
    DC%Knock 0.0
    Dc Offset Default
    With these settings I hit 17.7psi registered on the BSLCD. I'm using an external GM sensor to register boost. I can go into the Config Menu and test the Solenoid and I can hear it clicking fast.
    Medford OR
    I don't know or care about center port, left or right port, etc... I would worry about the flow being correct. You should have open flow from the Y-pipe to the actuators through the solenoid with it not energized. With it energized you should have the Y-pipe blocked, and the gates vented.
    0% duty cycle = no restriction.
    100% duty cycle = fully restricted.
    By the way, is it possible your hose is pinched (causing restriction to wastegate, and therefore raising boost).
