Results 1 to 8 of 8
Thread: Chromed ECU and Speedo Calibiration
    Nov 2013
    Stockton, England
    Hi all,
    I have a 3000GT motor in the back of a Rover Metro (UK) I'm building.
    I have a Chromed ECU (though not in the car yet) and have been reading loads about setting it up. My first problem is that I will have to make a new wiring loom as the previous owner made a right hash of it and reading ECU pinouts from the 93 wiring diagrams often do not correspond to the new ECU pinouts. Does anyone have a full Chromed ECU pinout list?
    Next question: Is there a way to calibrate the speedo sensor with Chrome?
    I have no ABS to take a speed signal from and my gearbox is an uprated Ford 4WD box which I could probably update to a later Ford Speedo sesnor to provide a signal, but would need to match the signal to a speed.
  2. The Following 2 Users Say Thank You to knights19 For This Useful Post:
  3. #2
    I can't help with the Chrome pinouts, but I'll give you a free bump. That's a really cool project you've got there!
    What I'd do for the speed sensor would be to use the Ford sensor and use a translator box to translate it to the Mitsu style signal (check the factory service manual for the 3000GT/GTO, I believe the signal is shown there)
    Send me a private message with your email address, and I'll email what you need.
  5. The Following User Says Thank You to BlackStealth For This Useful Post:
  6. #4
    I lack color... verified
    Aug 1998
    ECU doesn't operate the speedometer. That gets fed direct from the sensor on the trans.
  7. #5
    Nov 2013
    Stockton, England
    I've just got the transmission back from the builder so I'll check to see what it has. I see Burton Power do an adapter to fit a later electronic sensor, that could work.
  8. #6
    Nov 2013
    Stockton, England
    As I have no Mitsu speedo, I'll be using the Evoscan software to build a dash and would like to include a speedo. Can Evoscan use the OBD2 speed output from the ECU, or would that really only be CAN on later models?
  9. #7
    Aug 1998
    Yes EVOScan can show speed but the transmission sensor needs to send the pulses to the ECU like stock. One thing I never verified was if the speedometer reading was accurate in a 5 speed car with the Flash ECU. I'd assume it isn't meaning you might have to calibrate the log equation to match your true speed.
  10. #8
    Nov 2013
    Stockton, England
    making it more complicated is that I'm running a Ford 5 speed 4x4 box connected to it.
    but that sounds very complicated!
