Results 1 to 3 of 3
Thread: 1997 3000gt vr4 $10000 obo
    Apr 2012
    Davenport, Iowa (Quad Cities)
    For sale - 1997 Mitsubishi 3000gt vr4 10000 obo (((((((((((((((price drop to $8500))))))))))))))))))
    Ive had this car for about 5 years now, its time to move on. The car has undergone many modifications and work while ive owned it and almost everything mechanical in the entire car is new. Before i give you the list heres an over view. I took ownership at around 165k miles, and drove it for 3 years as a daily. After that the car was painted going from the faded red enamel stock paint, to Grabber blue. After another 5k miles i decided the motor needed rebuilt, (vss was going and was pushing 200k miles and needed various other parts) engine was rebuild at precisely 202675 miles. After that ive driven the car and performed a few more upgrades, i have pictures during the paint, body work stage, and while the engine was apart. Most of these parts and projects are on youtube, https://www.youtube.com/channel/UC73...dfjOg-cK_6bq7g.
    After the list i have typed up, i have the original for sale add back when i bought the car craigslist wont let me add the pdf. but i can email it to you if interested. Modern3kgt is the previous owners forum username so you can search and see more of the cars history on 3si or 3sgto my user name is viscousrealtime so you can search that as well. i love this car to death and it handles on rails and runs amazing, just looking to get out of the 3000gt scene as ive been in it going on 9 years. Call or text if you have any questions 314 four five eight 2624. All parts listed as installed are OEM unless other wise labled. Car is a 7 out of 10 condition wise, with the interior stripped, the paint has 3 chips that are somewhat noticeable and the car comes with touch up paint. i never attempted because im not the best with touch up. Price is 11k OBO which may seem high but is well worth the price with this many new parts and a fresh engine.
    What it needs - The Car has one CEL from only having one O2 sensor installed and needs a slim fan installed on the passenger side of the radiator(small fan turns on when prompted with climate control) . A wide band with O2 sensor is included with the car, it just has not been installed. craigslist add is at the bottom the add, has more pictures.
    please text or call i am not on the forum much.
    engine bay -
    stock rebuild, bored 3.01 over for cylinder wall wear.
    wiesco pistons
    arp head studs
    3sx fuel loop
    15t turbos installed, freshly rebuilt
    valve covers painted
    all new pulleys including oem harmonic balancer
    ac delete
    new oil pump and seals
    99 lifters
    new seals new gasket kits and piston rings and valve stem seals,
    rebalanced rotating assembly
    new oil pan
    new oil cooler
    new 3SX singlepass over sized radiator
    3sx abs delete, braided stainless lines
    Cruise control delete- used 2g eclipse straight throttle cable (new)
    New oil pump sending unit and light sensor
    New starter
    EGR Delete
    Vacuum Reduction
    HID hi and lows,
    Solid motor mounts
    Suspension / Steering
    Tien Flex coilovers (new)
    Addco upgraded front sway bar (New style)
    New Stop tec Rotors
    New Transmission axle seals,
    New Inner outer tie rods
    New front ball joints
    Rear adjustable upper control arms,
    Drivetrain
    Rebuilt transfer case
    New fluids in T case, trans (Mobile 1) and in Diff. (Redline)
    New Carrier Bearings
    New Competition stage 3 clutch,
    Clutch booster delete
    Lightweight fly wheel, (fidanza) rev matches, blips like a dream
    new transmission axle seals, new drivers side axle
    Exhaust-
    New Front Manifold, to Newly rebuild 15gs,
    3sx Down pipe, Modified with flex pipe to work with the aftermarket Manifolds
    Ips Exhaust
    4" Hks Carbon fiber Muffler
    Interior
    Blue corbeau Race seats - A bit beat up(bought after doing an autocross, because i was sliding all over the stock seats), car comes with a decent set of grey cloth seats also
    Originally car had leather power seats, but they were extremely heavy and the cloth or race seats give you a bit more pedal work room,
    rear of car interior is painted primer white, i was planning to install car carpet in the rear to match the front but never did.
    Tac - has LCDBC installed and works great, (manual monitoring gauge for just about anything this is the boost controller also) uses AEM solenoid
    True black dash is in good shape,
    3sx short shifter
    Wheels
    Older Rotas
    Come with alright condition Continental extreme contacts
    Exterior
    Painted grabber blue with a white primer
    angry eye mod done to the hood
    rear wiper and spoiler delete
    1g center garnish
    wingless hatch done correctly, holes welded with a patch, bondo skimmed sanded down and then painted.
    a large amount of bolts on the car body panels have been replaced with stainless, you know why.
    one small spot of rust behind passenger seat. on the center of the floor pan, it can be patched very easily.
    Fuel-
    Fuel pump upgraded to walboro 250
    Fuel Filter changed at 200 miles when fuel pump was replaced
    Extras uninstalled and included in price -
    Hks BOV real one, needs rebuilt but it is included, gasket kits run around 55 bucks, current BOV is a stock DSM BOV
    extra stripped and sanded 97 - 98 front bumper
    3sx fuel pump hot wire kit
    maft pro without the speed density sensors to run mafless
    Solid Differential Bushings
    3sx AWS delete
    stock cloth seats
    Aem Wideband with 02 sensor
    3SX Boost leak tester
    oem fog lights included not currently installed, they were removed from the car during the respray, the have been upgraded to yellow JDM style LED fog lights and will need brackets to be installed as the stock mounting brackets were lost.
    https://quadcities.craigslist.org/cto/5949452479.html
    thanks for your time.
    Apr 2012
    Thumbs up 1997 3000gt vr4 Price drop to $8500.
    Price dropped to $8500
    Kyle
    Apr 2012
    Bump bump bump it up
