1996 $ 4000
This 5 speed 3000GT is currently available. 176k miles. It has just received a new timing belt service (timing belt, water pump, pulleys, tensioner, cam seals, and crank seal), tune up (spark plugs and wires), new tires, new poly front control arm bushings, headlights were just refinished, new rear engine mount, and the exhaust was just repaired. Asking $4000 for this one. Clear coat failure on the hood, roof, and rear quarters. But it does shine up nice! It does smoke a little when sitting at idle for a long period of time due to valve stem seals. It is currently running 10w-30 engine oil. A thicker oil could help prevent that from happening. Oil pressure is fantastic!
