Results 1 to 1 of 1
Thread: 1997 3000gt vr4 $10500
    1997 $ 10500
    This 97 Mitsubishi 3000GT VR4 is a great modified street car. Featuring 388 awhp on pump gas, with the potential to go higher with E85 fuel. This car is setup to terrorize the streets! We have a freshly rebuilt stock engine in the car and resealed transmission. RPS clutch pressure plate with a new OEM clutch disc. Exhaust consists of an aftermarket downpipe, high flow main cat, precat delete pipes, and a JIC cat back exhaust. This thing sounds incredible! For air flow, it has a pair of TD04 16T turbochargers, front mount intercooler, Tial blow off valve, TurboXS manual boost controller, metal intake pipes, and an open element air filter. The car has a MAF translator in blow thru and an Apexi S-AFC2 for engine management. A set of larger fuel injectors (we believe they are 780cc) that are being pressurized by a hot-wired Walbro pump. Other modifications include a set of poly engine mounts, Tein S-tech lowering springs, new tires on freshly powder coated wheels, Autometer gauges in the dash, and AEM wideband and boost gauge mounted with a custom pod to replace the center vents.
    This car does have a reconstructed title.
    More pictures here. https://3swarehouse.com/product/1997...-3000gt-vr4-3/
