Quote Originally Posted by Lobo2112 View Post
Thanks for the input everyone. I had seen the post you linked while troubleshooting Greg, unfortunately I did not have the latest Evoscan available to me at the time, and was unable to update due to my only internet connection being on my phone. So I'd been doing everything the way the older threads suggested. I'll be remedying that this week as I do have internet here. I'm in an odd boat for working on the car because it's 3 hours away from me in the middle of nowhere (with shitty internet) and I can only get out there to work on it sporadically.
I'll also double check the ROM and make sure I didn't miss any peripheries. I had worked my way through the sticky step-by-step when I originally set up the ECU... but like I said it's still possible I missed one.
The car is not a swap, one sensor was replaced while I was rebuilding my rear subframe and upgrading the bushings and swaybar... due to a bit of carelessness on my part with the torch :-/ So the comment may well still be valid if I was sent the wrong sensor.
Thanks for the info on your car.
Seems like you have quite a job working on a car 3 hours away.
Speed sensor is probably right one if it was a direct replacement.
The reference i made was related to if the type of speed sensor used as the mechanical and electronics speed sensors are vastly different (you would know if it was the mechanical one as it doesn't have a wiring loom but rather a direct feed into the back of the dash cluster for speedo)
Yep get a hold of the most recent version of evoscan and see what DTC's show up.
Interested to see what happens for you.
I have a project car an hour away from me so I sort of relate with process of repair and renewal remotely
