Results 1 to 2 of 2
Thread: 1997 3000gt vr4 $13000
    1997 $ SOLD
    This is a gorgeous example of a 1997 Mitsubishi 3000GT VR4. We went through this car with a fine tooth comb and came out with this result. The car runs flawlessly and shifts very smooth through its newly rebuilt transmission. With only 122k miles on it and everything on the car is rebuilt or brand new; you will get a lot of life out of it. It comes with new tires on the factory wheels (which have chrome peeling). For an additional $500, we will install a brand new set of wheels/tires that are shown in the pictures in the gallery (dark stainless color 18×9). This car is currently running stock boost on stock turbo chargers. We’ll have dyno results added here shortly.
    Here is a list of the following things we did to the car and other items it has installed.
    New Engine!!!!! (New OEM short block with rebuilt cylinder heads and big bore lifters)
    Rebuilt Transmission
    New OEM Clutch Kit
    New Timing Belt Kit
    New A/C Dryer, Evaporator, and Expansion Valve
    New Prothane Front Control Arm Bushing Kit
    New Driveshaft Carrier Bearings
    New Hawk HP+ Front Brake Pads and Hawk HPS Rear Brake Pads
    New Spark Plugs
    New Upstream O2 Sensors
    New Vacuum Hoses
    New Fuel Filter
    New Tires (Nokian 245/40/18)
    New Fuel Pressure Solenoid
    Seattle Poly Engine Mount Kit (minus transmission mount)
    Turbo XS RFL Blow Off Valve
    Metal Y Pipe
    Dynamic Racing Exhaust Downpipe
    High Flow Cat
    Short Shifter
    Stainless Brake Lines
    Adjustable Rear Control Arms
    More pictures are available on our website. https://3swarehouse.com/product/1997...-3000gt-vr4-2/
    Update. We installed a brand new OEM short block and rebuilt cylinder heads in it over a week ago. Price went up $500 to $13,500
