1997 $ SOLD
This is a gorgeous example of a 1997 Mitsubishi 3000GT VR4. We went through this car with a fine tooth comb and came out with this result. The car runs flawlessly and shifts very smooth through its newly rebuilt transmission. With only 122k miles on it and everything on the car is rebuilt or brand new; you will get a lot of life out of it. It comes with new tires on the factory wheels (which have chrome peeling). For an additional $500, we will install a brand new set of wheels/tires that are shown in the pictures in the gallery (dark stainless color 18×9). This car is currently running stock boost on stock turbo chargers. We’ll have dyno results added here shortly.
Here is a list of the following things we did to the car and other items it has installed.
New Engine!!!!! (New OEM short block with rebuilt cylinder heads and big bore lifters)
Rebuilt Transmission
New OEM Clutch Kit
New Timing Belt Kit
New A/C Dryer, Evaporator, and Expansion Valve
New Prothane Front Control Arm Bushing Kit
New Driveshaft Carrier Bearings
New Hawk HP+ Front Brake Pads and Hawk HPS Rear Brake Pads
New Spark Plugs
New Upstream O2 Sensors
New Vacuum Hoses
New Fuel Filter
New Tires (Nokian 245/40/18)
New Fuel Pressure Solenoid
Seattle Poly Engine Mount Kit (minus transmission mount)
Turbo XS RFL Blow Off Valve
Metal Y Pipe
Dynamic Racing Exhaust Downpipe
High Flow Cat
Short Shifter
Stainless Brake Lines
Adjustable Rear Control Arms
More pictures are available on our website. https://3swarehouse.com/product/1997...-3000gt-vr4-2/
