oil contamination.
Hey if you want to run it I'm not going to argue with you, but if it starts smoking in a week don't be surprised.
oil contamination.
That's not what I meant, sorry. I was just curious how it could adversely affect the turbo.
no big deal. That thing looks oil soaked to me that's all. I'd hate to see you spend a couple hours replacing it again.
Me too. It also looks that bad because I'm halfway through cleaning it with carb cleaner. Unfortunately, I don't have the money for a rebuild kit right now for this thing, and the only reason I got a 13G over a 9b was that I got a deal on the 13G, and it was cheaper. That and the fact that I need this car running yesterday (yet again), make me more adverse to rebuilding it right now. A buddy has been helping me out, and he thinks the turbo is good as well, so I kind of have to take the chance. It's really a rock and a hard place I'm in. I may wind up rebuilding it in a few weeks, but I have no real choice, unfortunately.
That aside, any ideas WTF is up with the exhaust housing or how to fix it?
OK, so I tried it again on a whim, and the damn thing spun in the exhaust housing. No friggin idea. But it still does spin as freely as it should. Any ideas what it could be??
you got pics of it put together? Once I get them most of the way together I put the clamp on and ever so carefully tighten it.
How tight is ever so tightly?? I watch both turbines to check for clearance when I'm tightening it. When you assemble yours, is there always a gap between the shaft housing (not sure if that's what it's called. I'm referring to the middle part where the oil and coolant lines are), and the exhaust housing?? I always have a 1/4 inch gap for some reason. It makes me think it's binding somewhere, but when I take it all apart, there are no scratches anywhere.
No, the gap shouldn't be that big, the pieces should be touching. The clamp doesn't need to be super tight.
Then there is my issue. But why won't the gap close?? What could cause that?
the only thing I can think of is the compressor housing on one of them has been changed out at one point or something has been machined and your lip sizes don't really match. Measure the 13G cartridge lip and your old 9b one and see if it is the same.
