Results 1 to 10 of 11
Thread: Big scratch on my Mitsubishi please help
    Sep 2016
    Post Big scratch on my Mitsubishi please help
    Hey guys,
    Late the other night I had a very rude awakening by my car alarm going off so as most people would do i looked out the window, seen nothing went downstairs turned the alarm off and seen no one in site (thinking maybe a glitch or a cat or something).The next day i get up as usual go to work as normal park the Mitsubishi 3000gt up and did what i had to do in work. When finishing i exited the building and it must have been one of the worst days of my life there is a 3 foot key scratch down the passenger side of my Mitsubishi… furious!! if i catch the mother****** who did this, well….
    Anyway now my rant is over I have to fix this problem at the minute I am using a black marker pen to hide the scratch the best I can, but I know it is there and it is driving me crazy. I am here for your guidance and help I have been out and brought a car polisher for sale/waxing kit for sale at the local auto store and some metallic T-CUT. So now the process of how to clean the Mitsubishi, wax and blend he scratch in, I’m a little lost i might even need more products for the Mitsubishi but I have no idea..
    Any advice/information will be mu appreciated, I will give anything a go that you throw my way before I have to take her in for a re-spray which I’m not looking forward to.
    SPECS
    Year: 1999
    Color: Metallic Black
    If there is any other information needed just let me know and I will add it on!!!
    Thanks guys
    Forum User Feedback Score 0 box's Avatar
    Jan 2011
    That's shit.
    Give us a good, high resolution picture of the scratch from front on and at an angle so we can see what you're dealing with.
    Sep 2016
    No problem i can get one up in a couple hours
    Sep 2016
    Sorry about the poor picture quality but that's the best i can get before it just blurs out
    Sep 2016
    BTW that's not the whole scratch just the deepest part
    Monogamous Gigolo verified Feedback Score 8 (100%) 2fnloud's Avatar
    Sucks that this happened but how exactly can we help? Yes it is a bad scratch, yes it will need to be painted. what type of insurance do you have?
    Forum User Not Verified Feedback Score 2 (100%) sohcstealth's Avatar
    Feb 2014
    2002 and 2014
    Hamilton, Ontario, Canada
    General rule of thumb. If you can catch your fingernail on the scratch, it can not be buffed out and will require a repaint.
    Sorry about the car man, totally sucks!
    Southernmost 3S Owner supporter Feedback Score 0 93STLTH's Avatar
    Key Largo, FL
    I've had pretty good results using the Dr. Colorchip system on small scratches and rock chips. Yours seems a little deeper than just a scratch, but it might work as a temporary fix.
    2013 NG: 1st place, FWD Drags
    BAD ASS - I've got one Not Verified Feedback Score 9 (100%) j2k4's Avatar
    You might give some thought to your enemies list.
    Such things do occasionally happen because of mental-defectives, but I'm thinking someone may be pissed at you, in which case you might also want to deploy a camera and bust someone.
    Sep 2016
    Your right!! cameras is my next move after trying the finger nail tip and the Dr. Colorchip. If not Paint shop here i come....
    Thanks for the info guys hopefully the Dr. Colorchip works
