Results 1 to 3 of 3
Thread: Netbook battery/charging problem
    I have a several year-old HP 5101 netbook that has been demoted to auto-flashing/tuning duty, but is still a fully-functioning unit, until now.
    It has the N280/1.66G proc, 2G RAM, 160G HDD, blah, blah, blah.
    When I bought it, I'd also gotten the accessory 9-cell battery for longer off-charge life.
    During the winter, when the car was parked, I got into the habit of leaving it plugged-in on the end-table next to my easy-chair.
    This past spring, I had to do a flash on the car, then back in the house next to my chair.
    Back story: the unit was an XP machine when I got it - I did a legit upgrade to Win7, and - surprise, surprise - the hardware was good enough to take Win10, which was installed via the auto-update method.
    I was okay with that - it taxed the unit a little, slowed it down a little, but it worked well enough, and it was fine for the car-stuff.
    About a month ago, I noticed the battery was not charging...I thought the battery took a shit, so I subbed-in the OE 6-cell (which had never been used) to no avail.
    The unit works fine when plugged in, just doesn't charge.
    I disabled/uninstalled/reinstalled drivers, etc, again, to no avail; the machine says all is good.
    My assumption, therefore, is that the PC-end of the charging hardware is on the blink and the batts are okay.
    I even retro-installed Win7 (wouldn't validate, I assume because the code was still in play for the defunct Win10 install), then the original copy of XP, to ensure it wasn't wasn't a driver-issue - neither worked.
    I still want to make this usable for auto-work, as my Lenovo lappy is large-ish for in-car work.
    I'm not inclined to pay for pro-service on this thing, but I also just saw a 5101 (no HDD, charger, etc) on ebay for $40.
    Give me some ideas, fellers...
    I only have a lot of experience with Dells, but when they do this its the charger that's went bad usually. On rare occasion the battery. Since you tested a different battery its either the charger or the charging circuitry on the board, but that's probably not worth fixing.
  3. The Following User Says Thank You to Chris@Rvengeperformance For This Useful Post:
  4. #3
    Ah, hadn't thought of the charger, Chris.
    I'll check that forthwith; I have the 12V unit to verify.
