1994 $ SOLD
This 1994 Mitsubishi 3000GT VR4 comes in the rare Martinique Yellow color. The paint on this car is in great condition with only some minor scuffs on the bottom of the front bumper and some rock chips on the hood. We just recently rebuilt the engine in this car and it has been broken in and the oil changed. The transmission was also rebuilt and features new syncronizers for 1/2 gear, as well as a billet shift fork for those gears. All new seals were installed in the transmission as well. A new OEM clutch kit was installed as well. The electronic suspension works perfectly. We installed new poly Super Pro front control arm bushings (lifetime warranty). A new walbro 255 fuel pump was installed as well. The car runs and drives great. Tires have approximately 1000 miles on them. The brake system was fully inspected and the front rotors were resurfaced. This car will need nothing but regular maintenance in the future. Active aero still functions (front and rear). There are only 115k miles on this chassis!
Rebuilt engine consists of the following parts:
New stock sized piston/ring set
Refurbished OEM connecting rods
Polished OEM forged crankshaft (stock size)
Clevite H series rod and main bearings (stock size)
King thrust bearings
Engine block honed, tanked, new freeze plugs and oil galley plugs
Fel-pro PermaTorque head gaskets
OEM gaskets (except head gaskets)
New oil pump gears
New timing belt kit (water pump, timing belt, pulleys, and OEM tensioner)
Rebuilt cylinder heads (clean and blast, valve job, resurface, vacuum test)
We currently have it listed on ebay, here. http://www.ebay.com/itm/162197222215
Or our website, here. https://3swarehouse.com/product/1994...-3000gt-vr4-5/
