Results 11 to 20 of 22
Thread: My projects v2
    Silly DSMs...
  2. The Following User Says Thank You to DocWalt For This Useful Post:
  3. #12
    Mar 2014
    I do like the talon. i recall racing one back in 1990 against my dodge daytona
    I recently joined a dsm forum, I don't know if you are member there http://www.dsmtalk.com/forums/index.php
    Built 2nd week of August 1992 as a 1 of 11 1993 Dodge Stealth R/T twin turbo (6g72 engine with stock TD04-9b turbochargers), pearl white exterior (W29), red leather interior, W5MG1 transaxle. Low mileage, just 68000 miles!
    Current modifications are: VMS racing 10.2mm spark plug wires & NGK BKR6EIX-11 spark plugs gapped down to 0.32", Touren TR9 3190 wheels, Maximal high flow main catalytic converter, gutted/deleted precatalytic converters, front & rear slotted & drilled brake rotors from ebay, T-bolt stainless clamps, Curt trailer hitch, rear bumper aluminum reinforcement from a 2nd gen car, LED backup & license plate bulbs, Pioneer AVH-X2500BT with backup camera, DSM SMICs converted by oohnoo, 3S warehouse sidemount oil cooler, Hurst shifter handle, EGR blockoff plates, Stainless bolt kit, LCDBC as an ECU monitor, 3SX Stainless-Steel Braided Brake Lines, Koyo radiator with brackets, Retractable license plate holder, 3SX rear control arms, Snake eye mod, Brake Caliper Stiffening Bolts, Pilot WI-HL6A 4656 Head Lamp Conversion Kit
  4. #13
    iowa
    Yea I'ma members on most of the. From back when I had my drag talon . I had a guy make me an offer on the talon and another on the engine . Actually came out 500$ ahead.
    And then the bmw shit a water pump , so I did the logical thing.... Ordered a water pump. Front and rear brake pads and rotors , ss brake lines , new shocks and struts ....
    Sent from my XT1650 using Tapatalk
  5. #14
    Hahah, "while you have the car apart"
  6. The Following User Says Thank You to DocWalt For This Useful Post:
  7. #15
    iowa
    Struts and shocks haven't come yet , I honestly went against buying a 1k$ set of coils in favor of standard stuff . For one I don't track like you guys just spirited driving and for the drop in and go ability I figured It would be easier
  8. #16
    I lack color... verified
    Aug 1998
    Hey you are still alive! Figured you had gotten all old and antisocial by now.
  9. #17
    iowa
    I am old and anti social lol
  10. #18
    iowa
    So I tackled the water pump today. Really surprising easy . I would equate it to a old small block Ford water pump . Only nuance is the rad does not have a pet cock . Also managed to track down my oil leak , which is coming from the vanos solenoids . Had done valve cover earlier this year thinking that was it .
    So new water pump , t stat, clutch fan and pentosin coolant . Only two fluids that have not been changed on the car now are brake ( soon rbf600) and power steering .
    Also found a slightly loose inner tie rod .... Never ends.
    My rear shocks have shown up but not the new top mounts . The new struts have not shipped yet so that stuff will most likely get pushed off till winter so I can enjoy the car a bit before .
  11. #19
    iowa
    Yes rancho shocks ! Long story short but they perform on par if not better than Bilstein adjustables at 1/4 the price and have more piston area . The shocks are actually "for " a Toyota Tacoma .
    On a side not I have been hand laying sticker bomb to my bicycle as I get them
  12. #20
    Andover, MN
    The Vanos solenoids like to leak as well as the oil filter housing gaskets. Thank god they are on top where they are easy to change.
