Results 1 to 4 of 4
Thread: Corrupted WOT logs
    Aug 2014
    Finland
    Question Corrupted WOT logs
    My WOT logs seem to corrupt for some reason and it's making tuning somewhat impossible. Look at the bouncy RPM entries (5k and up), there is also exact same RPM at rows 18, 21 & 22. I can't see how my changes affect my power since my logs look like this. At first I thought it was because my laptop is REALLY old, but I tried Openport 2.0 standalone logging and it still looks the same (SD-card is Class 10). Anyone had this same problem or know what to do?
    Jun 2016
    Chicago Southside
    Im having this exact same problem! Rpms jump all over the place on the logs and only after 5k... Im curious, are you using chrome ecu on 1g car(CAS)? Been chasing this for awhile now thinking something was wrong(I tried swapping the cas, ptu, coils, tested harness, etc)but im leaning towards it just being the latency difference between the early 1g Cas and the 2g Hall effect sensors.. It didn't bother me too much at first but more so now that i'm pushing the ignition timing and boost Id like to utilize VD in evoscan but its almost impossible to get a clean log. Luckily i'm still on pumpgas so I can rely on the knock sensor for now but i'm curious what others have done to get past this..especially the E85 guys since you can not rely on the knock sensor.
    Aug 2014
    Finland
    Yes It's a 1g car with Chromed ECU. I did think it could be EMI interference since I'm running HKS DLI with non-resistor spark plugs, but I unplugged the DLI and it made no difference.
    Fowlerville, MI
    I had a similar problem. Never fixed it before I sold the car. Never caused an issue with it running through, so I didn't dig into it.
