Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
Thread: Replacing turbos
    Jul 2014
    March 2016
    Replacing turbos
    I am looking into learning about replacing the twin turbos on my VR4. It contains 16g turbos and has Series 1 AEM Electronics. There is an Apexi gauge and an HKS boost controller, and a turbo timer also installed. The exact names of those are on a build list in my garage page.
    What I want to ask and learn about is the following:
    I am pushing 600HP with 12psi of boost. I am looking to put over the years 1000hp before I'm all done with the engine. For now, I am looking to get around 600-650HP but I want to also increase the amount of torque as well. I believe I am producing 404ft lb based on the paperwork that came with the vehicle but it is not the most accurate numbers I got in terms of HP and torque. I believe I may have 400-500ft lb torque but do not know how or even when I want to try to find an accurate number for this. Is it fesible to place slightly larger turbos in the vehicle? What should I be looking at performing on my vehicle to increase the torque and HP?
    My end goals for the engine will be 1000-1200HP and at least 800ft lb of torque. This isn't needed for many years, but slowly and surely I will achieve it. I will want a 300M steel drive shaft and a twin disc clutch with pedal stop as well for that.
    Fowlerville, MI
    Sep 2012
    Decatur, TN
    Quote Originally Posted by EmeraldRegice View Post
    If you actually have 16Gs, 12psi isn't anywhere near enough to make 600hp on them. You would want to look at turning the boost up before going bigger.
    Your best bet is to get the car on a dyno and see what it's actually making for power. You may need bigger injectors to increase the boost, but it's well worth it as 16Gs are really going to shine at 25-30psi. Look at improving your current output before deciding you need bigger.
    As far as driveshafts, there is no 300M driveshaft, there are aluminum and carbon fiber options. 300M is what upgraded output shafts and input spools are made of.
    Sent from my Nexus 6P using Tapatalk
    He's probably thinking about 300M rear axles, but after he buys them from DSS he'll get a shock when they are weaker than stock axles and they won't warranty them.
  5. The Following User Says Thank You to anyonebutme For This Useful Post:
  6. #5
    Player Hater of the Year
    San Antonio, TX
    LOL 600 horse on 12 pounds!
    In order to get better performance, pay somebody to do it for you.
    Aren't you the person with the nitrous question, browning shift dildo and the space age steering wheel?
  7. #6
    VR-3747 :D Not Verified
    Dayton Ohio
    Emerald... your question is incredibly naive... you gotta do some research. You're way off base right now.
  8. #7
    Never finishes any verified
    Wake Forest, NC
    Seeing as you just messaged me regarding what the red wires were in your engine bay, which are your spark plug wires, you just need to shut the hood on that car and step away.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  9. #8
    Fowlerville, MI
    I swear this is a troll account.
  10. #9
    Oct 2010
    Sep 2009 - Jan 2011 - 1991 Dodge Stealth RIP, Sep 2012 - Present 1994 VR4
    Dallas, TX
    Only way any of this even makes sense.
    1994 VR4
    MAFT, Z06 MAF, Cruise Control Relocation Mod
    BlackStealth LCDBC/MAC Solenoid/eBay GM 3 Bar MAP
    GZP Pre-set Cam Gears, Hotwired Pump and Bypassed Fuel Relay
    Short throw shifter mod w/ solid bushings/bearings
    M2 Turbo Back Exhaust, Gutted Rear Cat
    Clutch Reservoir Deleted, BlackStealth Datalogger
    Vacuum Reduction, EGR Delete, Resistor Mod
    HKS SSQV BOV Recirculating
    Tein S-Tech Lowering Springs
    FR500 18x9 Rims
  11. #10
    My brain hurts after reading this.
