1994 $ SOLD
https://3swarehouse.com/product/1994...rt-twin-turbo/
This is a beautiful example of a 94 Stealth R/T Twin Turbo. It is one of 43 made in this silver color for the 1994 model year. Only 8 are made exactly like this one. This car is currently sitting at 96k miles. All of the major service work has just been performed and it's running and driving just like new! The interior is charcoal grey with some black Corbeau racing seats and custom rear seats that are black/grey. The front seats have Corbeau racing harnesses as well. A Turbosmart electronic boost controller sits on top of the steering column for easy access and safe reading. There is also an aftermarket radio in the car. The interior is overall in good condition. There is a small burn mark on the bottom of the rear seat.
The exterior is all stock except for a 99 front bumper and turn signals. It does have some rock chips in the hood and fenders. We will be having the dent in the passenger side front fender removed with paintless dent removal before the car is sold. Light scratches are on some of the panels, but they are not very noticeable. Overall, the paint is in good condition for a 23 year old car. It is sitting on a set of Wedsport 17 x 8.5 inch wheels with brand new Nokian Z Line tires in 245/45/17 size. These tires are very sticky and offer great traction. The wheels do have some minor curb rash on a couple of them, but are in overall good condition.
Suspension for the car is a set of Tein coilovers with adjustable front camber plates. These are in good condition with no visible leaking and no corrosion/rust that would keep them from being adjustable. We installed a new front wheel hub on the driver side as the bearing had some play. Also installed are new ball joints and tie rod ends. The driveshaft received new carrier bearings and the rear differential received a set of poly bushings.
As for the engine. We did a complete service to it. The upper and lower intake manifolds are freshly powder coated and all new gaskets are installed on them and the fuel injectors. The front valve cover was also powder coated in an OEM crinkle black finish. New valve cover gaskets were installed front and rear. A new timing belt set was also installed, along with new front cam seals. New accessory belts were installed and the idler and tensioner pulley for the alternator/ac belt were replaced. Spark plugs were changed to some copper Denso plugs gapped at 0.028". A new K&N intake filter was also installed as well as an engine bay bolt kit was also added that includes stainless allen head bolts with black aluminum washers. Oil was changed with fully synthetic Royal Purple engine oil.
Other modifications include a custom cat-back exhaust, HKS blow off valve, CXRacing intercooler kit, and CXRacing intake pipes.
