I doubt anyone can pull hard enough to make the belt fall into a cog it shouldn't be in, or to damage the belt. The only fear I would have from pulling too hard is moving the gears it's already set on. You have a bad experience with that or what?
Sounds like you're routing it with the right amount of tension and leaving the slack in the correct area, but you were using the method for those who don't.
