Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 50
Thread: putting on timing belt, have couple of questions
  1. #31
    Canaan NH
    I am with the majority here. Start at crank, move to rear then front and leave the slack at the tensioner. So easy a cave man could do it, or even me.
  2. #32
    | @/|/| +|2()|/| verified
    December 2009
    Fox Cities, WI
    Im surprised no one has mentioned cam lockers . I did mine from crank to rear cams to water pump to front cams to tension. Had it back one tooth on the crank. Made sure I was setting the belt on the gears tight. Worked the first try It was my first timing belt ever o.O Also I used clips to hold the belt on the cams.. Just cause
  3. #33
    Texas
    Quote Originally Posted by terrets View Post
    Cause you don't need any of that crap if you do it backwards.
  4. #34
    December 2009
    Fox Cities, WI
    Well I think using cam lockers on the front cams makes life easier. I got the rear two cams to chill on their marks but the front two wouldnt.
    When I did my 180k maintance....I found the tensioner pulley was upside down!!! The belt was being warn from the bolt that holds the bracket.
  5. #35
    Wrench Monkey Not Verified
    Rochester, NY
    Woah, that's a scary thought. ^^
  6. #36
    Honda Eater
    April 2007
    Ontario, Canada
    yea that is scary!!
    i have the cam lockers and the tool (obv). Set the crank back a tooth, and things went very smoothly.. But everyone has their own method, to one their own
  7. #37
    the BOSS of jellow supporter
    May 2005
    Dairyland
    so, looks like as long as everything aligned with right tension and pin can be removed and inserted back in, than its all good. no matter the way you do it.
  8. #38
    Texas
    Quote Originally Posted by a2j View Post
    Yes, but getting to this point when you are inexperienced with timing a 6G72 can be very frustrating.
  9. #39
    December 2009
    Fox Cities, WI
    ^ T'wasnt for me.
    Ya it was a bit scary Good thing I didnt put it back together like that too Hehe
  10. #40
    May 2005
    Dairyland
    alright, I will give it 12-16 hours and recheck everything just to be sure. my marks, tension and pin are where they suppose to be.
