I am with the majority here. Start at crank, move to rear then front and leave the slack at the tensioner. So easy a cave man could do it, or even me.
Im surprised no one has mentioned cam lockers. I did mine from crank to rear cams to water pump to front cams to tension. Had it back one tooth on the crank. Made sure I was setting the belt on the gears tight. Worked the first try
It was my first timing belt ever o.O Also I used clips to hold the belt on the cams.. Just cause
Well I think using cam lockers on the front cams makes life easier. I got the rear two cams to chill on their marks but the front two wouldnt.
When I did my 180k maintance....I found the tensioner pulley was upside down!!! The belt was being warn from the bolt that holds the bracket.![]()
Woah, that's a scary thought. ^^
yea that is scary!!
i have the cam lockers and the tool (obv). Set the crank back a tooth, and things went very smoothly.. But everyone has their own method, to one their own![]()
so, looks like as long as everything aligned with right tension and pin can be removed and inserted back in, than its all good. no matter the way you do it.
^ T'wasnt for me.
Ya it was a bit scaryGood thing I didnt put it back together like that too
Hehe
alright, I will give it 12-16 hours and recheck everything just to be sure. my marks, tension and pin are where they suppose to be.
