Page 1 of 5 123 ... LastLast
Results 1 to 10 of 50
Thread: putting on timing belt, have couple of questions
    the BOSS of jellow supporter Feedback Score 0 a2j's Avatar
    May 2005
    Dairyland
    I'm trying to follow manual to put the new timing belt on.
    I have removed the camshafts and didn't mark anything on the old belt. also was moving crankshaft back and forth. (I was doing VSS and lifters)
    so I realigned cam gears, and set crank sprocket 1 tooth back. but when I install everything and make the belt tight with tensioner pulley, the crankshaft is still 1 tooth behind. what am I doing wrong?
    Sthrn NH/Eastern Ma
    When you tighten up your tensioner pulley make sure you pull any slack up from the bottom, not down from the top. What's happening is that you're pulling the cams off 1/2 a tooth, instead of pulling the crank in a full tooth. It helps to have someone hold the front cam still...
    I've always just lined everything up exact and lock the cams in place...that's how I've always done it and never had a problem.
    Forum User verified Feedback Score 1 (100%) Amphiron's Avatar
    Quote Originally Posted by a2j View Post
    try compensating by setting it one tooth ahead
    May 2005
    Dairyland
    Quote Originally Posted by Steve '92ES View Post
    the only slack I ended up with is where tensioner pulley is. and when I tighten it up, nothing else moves. so right now I have no slack, everything is tight and crank shaft is 1 tooth off. I was thinking to do the way Mean Green described. I have no other explanation to what is going on, so far.
    May 2005
    Dairyland
    Quote Originally Posted by Amphiron View Post
    I'll end up that way at the end. nothing moves when I finishig with tensioner pulley.
    yeah, you want to lock the cams and have slack between the front ex cam and the crank....then you tension, and crank rolls clockwise 1 tooth in the process..."usually", lol.
    Born To Build Feedback Score 0 Bluejediz's Avatar
    June 2009
    Central, MN
    Quote Originally Posted by Mean Green View Post
    x2...Thats the way ive done it on every tbelt job ive done. As long as there is NO slack anywhere except where the tensioner is and you spin everything around several times and its still lined up then your golden!
    Sthrn NH/Eastern Ma
    Try putting the belt back on, following the order given in the manual EXACTLY: start with the front cam, clip the belt on with a binder clip, then the second cam and another clip, around the water pump, etc. I've seen people suggest going backwards, starting with the rear most cam, but it's been my experience that leads to the exact problem you're having. Cam lockers would be handy and there's plenty of home-made ideas around but if you don't have any having someone hold the front cam still can help. If after re-installing the belt you still can't pull the crank into alignment go ahead and put it on the mark and tension it up. If everything stays in alignment after spinning it around a few times, and the pin on the tensioner slides in and out, you're probably good....
    Rochester, NY
    That's because you're doing it the right way. When you do it the right way, you don't need to set the crank back a tooth. Just line everything up and leave all the slack in the tensioner area like you did. You'll be fine.
