Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Brain teaser....
    Medford OR
    And it looks like this all may have been just an exercise.... The Datsun wiper motor is about done. It's pretty common for them to be really weak, and not want to move well unless the windshield is wet. This one is worse than most, and they aren't easily sourced. The fix is to adapt a Honda wiper motor in it's place, which comes with a different set of wiring issues.
    Looks like I'll be able to make it happen with the same two relays, but the configuration is going to change significantly....
    Jan 2011
    Oh fuck me, worked it out yesterday but now I've just realized that the answer was already posted two posts above mine. Ahhh well, 10 points for participation.
    Medford OR
    I have run into a challenge I didn't expect... Going to have to ponder it a bit.
    Due to the configuration of the GM switch, I have to have a relay engaged to park the wipers. Every time I cycle the key on and off, the delay time for relay engagement allows for a very small bump in motor rotation. It takes about 4-5 key cycles to bump the motor out of the park switch, and sweep the wipers once to re-park.
    The only solution I've come up with so far, is to put the wipers on an accessory relay, so that delay time is matched...
