i'm at the point where the crank pulley needs to come off in order to pull the remainder of the timing cover...
the vehicle is on a flat surface.. the rear wheels are chocked... front is sitting on two jack stands and a 3 ton jack with another jack holding the engine up (for removal of main mount)... vehicle is not in gear... timing is not at DTC... cams 1 and 2 are 29 teeth from lining up ... cams 3 and 4 are 28 teeth from lining up ... cam #3 and #4 (closest to the front bumper) are both off by one tooth ...
Question: Given the above set of circumstances, will using an impact gun to loosen the crank pulley turn the timing belt? .. obviously, i don't want to bump the engine and risk damaging anything on the valve train ... thanks
