Installed a Greddy profec b spec 2 boost solenoid in my 95 vr4, no matter what I change my waste gate duty cycle too it just stays spiking to 20 psi and tapering off to 10, what's the correct way to tune in higher boost "airflow" on chrome
Do you have the boost load compensation enabled?
I actually started reading your thread and set all values to 0 for now, now I'm actually able to get the boost I want. Other thing is and it did this before too the selonoid is wicked noisy it's constantly clicking rapidly. I did read somewhere that this just happens though
Keep the boost load compensation disabled until you start getting a feel for which duty cycle you need the enable to compensation and go through those tables.
Setting up the compensation and load stuff takes a while but it's a great feature. It keeps your power constant even if the weather and temperature changes. It also helps to reduce boost spikes and boost creep.
Yeah that's understandable cause it's going for airflow at this point not just a psi level
