Yes, because it draws the same amount of current as stock solenoid so you dont risk frying the circuit in the ECU.
It also looks stockish
Sent from my SAMSUNG-SM-G900A using Tapatalk
Good point!
I've been running 17psi with 93 octane, a cheap 3sx manual boost valve, stock injectors, stock ECU without any A/F correction in my TT fwd base 3kgt. My only mods are an Aeromotive boost compensated FPR, 15Gs, and methanol injection starting at 12psi. My AFR under boost is 11.0. I am pretty happy with the way it is running. Before this I was using an SAFC and 450cc injectors. Honestly, I don't see much difference in performance at this level of boost. I never ran any higher than 17psi so for me the 450cc aren't really needed. When I need to pass emissions, I just go back to the stock boost valve.
91 R/T TT
I am currently using the coolingmist.com stage one kit. I use the windshield washer reservoir to hold the 50/50 water methanol and it can clean my windowsYou can actually mix methanol or "heat" with your washer fluid if you wanted. I use distilled water, though.
Pretty sure 15G's flow way more air at the same PSI as 9bs. Meaning, 15PSI might not be safe. Read a lot about people getting knock at 10-12psi on stock fuel system.
