Results 1 to 5 of 5
Thread: Battery draining
    Battery draining
    I found my battery drained after just a few days. measured 3.5A from + to car ground.
    i tried unplugging all the fused on by one, in both engine bay and driver side box, but no change...oh, expect the ALT, BAT and ABS..
    So what could be causing the drain?
    Yes, I really can DJ from my car...
    Myrtle Beach, SC
    These are all the obvious ones but sometimes we forget to check the obvious sooo...did you check to make sure nothing was plugged into your 12V Accessory outlet(s)? Didn't leave a door wedged open? How about a visor with a lighted mirror? Hatch was closed all the way? Do you have a sound system? Aftermarket Radio? Headlight switch is off, right?
    Those are the primary basic ones I can think of off-hand.
    91 Stealth RT/TT -New Mitsu Complete Shortblock, 13G TD04 Turbos, GReddy BOV, CXRacing SMIC Intercoolers with full Hard Pipes kit, Stillen Downpipe
    Stillen Intake, DN Polished Y-Pipe, Borla Catback Exhaust system, MSD Performance Wires, Vac Delete, 550 DR Injectors, HKS Boost Controller, HKS Super AFR, Rebuilt ECU, RPS Max Street Clutch and Pressure Plate, Crossdrilled & Slotted Rotors all around with Ceramic Pads, Stainless Braided Brake Lines w/ Red jackets all around, CXRacing 14kg Fully Adjustable Coilover Suspension, BT Freestyle 1-Off 18" Rims on 245/40/18's
    Medford OR
    There is absolutely nothing electrical in these cars with the exception of the starter that isn't on a fuse link... If you truly pulled all the fuses except 3, you need to look at those three, or something added aftermarket.
    Never finishes any verified
    Wake Forest, NC
    You need to do a parasitic drain test to find where the draw is coming from.
    Disconnect negative terminal and run multimeter in amperage mode between battery and cable. Be sure all lights and everything are off or you could damage the MM as most are only rated for 10 amp draw unless you have something like a higher end Fluke model. Then start pulling fuses. You should be under 0.3 ma, if not then you have something on puling power. At that point start pulling fuses in the engine bay to see where it is coming from.
    Google "How to perform a parasitic battery drain" for more info.
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
    Medford OR
    I thought when I originally posted that was what was being done... Now that I read it again, there may be an issue with the testing method...
