http://www.3sgto.org/threads/11388-T...iny-TD04-Build
Becauseracecar. $15000 and it's yours.
I will part it out of I don't get enough interest. (Here is some of the stuff included on the car, brand new everything) I will also include everything I have dealing with the car (lots of random parts including a short block)
Built Pampena 3.1 6g72 w/ rays custom ross pistons with upgraded pins - oliver billet rods - new OEM forged crank
Pampena 5 speed with 300m 25spline OS
Clutchmasters 850 series (8.5'') Stage7/8 - 2 Lightweight Unsprung Race Disks
Broomfield Racing Billet Transfercase
Port and Polished Heads - Pinned - +1mm exhaust valves and GZP +1 and -3 degree cam gears
GCTech Tubular td04 front & rear manifolds + rear o2 housing with Ceramic Coating
Dynamic Racing DR-750r turbos
STM tank to rail fuel kit
HKS Twin Power
Apexi S-ITC
ABS Delete
Austin@STM's Front hubs w/ ABS Sensor delete
Austin@STM's Driver side intake manifold.
Austin@STM's old stripped down VIS Carbon Fiber hood
Austin@STM's Half size koyo race radiator
Bought about $2400 in OEM parts to make this whole long block build fresh (Thanks Chris)
DR ARC-2 w/ 92mm MAS
BlackStealths LCD Boost Controller w/ MAC Valve
Greddy SMI Boost/Water Temp/Oil Pressure Gauge w/ controller
Deatschwerks Injectors 1000CC Injectors
Walbro 400lph E85 Pump
Treadstone TR1235 Intercooler w/ Custom Hard piping Thanks to Dave@Pampena
Megan Coil Overs
Corbeau Forza Sports
Maximal Adjustable Control Arms
STM Standard Oil Cooler
Maximal Solid Mounts
David's Replacement Trans Mount
Ninja Performance IAC Block
Pampena Billet Rear Diff Bushings
TiAL Q BOV
Pampena AWS Delete
Austin@STM's VIS CF Hatch
Solid Rear Diff Bushings
Krank Vents
Street/Strip Cage
AX6 Front & Bobcat Rears w/ Power Slot Rotors - Brakes
ACPT CFDS
Aftermarket Radiator w/ pipes
Very short exhaust
Weds TC105N's
Vibrant 6 port vacuum block (piece of shit out of the box)
Torque Solution Solid Shiter Base Bushings
STM Shifter Cable Bushings
Greddy Magnetic Oil Drain Plug (so fancy)
New OEM Oil Cap (just because)
NRG Purple Lug Nuts (because rice)
STM's Light Weight battery kit
Fiberglass and Carbon/Kevlar Doors
Carbon Fiber 99 Sail Panels
Chromed ECU (99 Flash Ecu)
