I could never play FPS's with a trackball. Yikes.
I play FPS's with a gun.
Picked up an xps 9350 (skylake) and a samsung 950 pro:
I get about 1700 mb/s read. There is some limitation in the pci-e lanes, although the samsung magician says x4 is being used. In real use its not any faster than drives I've had before, kinda wish I would've got a larger slower drive instead.
Battery life is insane on this laptop. A real 10+ hours.
Which Skylake?
1st issue, and trip to tech support. The dedicated headphone jack is not working proper. It shuts the speakers down when inserted, but no sound in headphones. There is should be a dialog that comes up when inserted asking what the hardware being used is to apply the correct settings in the driver. This no longer appears.
Uninstalled all audio devices, and restarted to no avail. Swapped to the direct out audio jack, and we have audio.
Contact tech support via MSI site, and the first thing they want is a factory reset! #*&^WTF%#! No uninstalling prior Winder updates, not reverting drivers, yup wipe the thing, and start fresh. Which I already know will net me that same problem, but must bow to the order if I want it fixed...![]()
That blows. I've not had issues with that on mine, so idk.
Try updating bios. Also try another set of headphones.
Sent from my SAMSUNG-SM-G900A using Tapatalk
I re-imaged it. Apparently MS decided to release an update incompatible with the sound card driver. All is as it should be but for the programs to reinstall...
Auto updated last night so will see if it fubar'd it again when home.
