Results 1 to 10 of 14
Thread: Power steering leak
    Nov 2015
    Power steering leak
    So, got my new vr4 to replace my totaled stealth, charged the a/c, hop in and start driving. Boom, no power steering. At first I thought the shop did something stupid and crushed a power steering line when they checked for a/c leaks, but now that I've found the leak I'm guessing it's more coincidence. Though if any of you think otherwise from the pictures, that'd be interesting
    But onto the main question.: I'm only a hobby-mechanic, don't really do anything intense. I'm slowly learning more and tackling bigger jobs on these cars, from the pictures/video, does this look like an easy fix? Is it just tightening that nut, or does it look like th e o-ring is bad? Whatever the case, what would me fixing it entail? Hopefully not a new rack, as this one is new.
    It seems that the leak is at the nut where the pressure tube connects to the valve housing.
    And if that video doesn't load
    vimeo.com/161564471
    Sent from my SM-N910P using Tapatalk
    Man vs 3/S verified
    Kingston, WA
    That fitting is metal to metal, its a tube/flare fitting. It may seal up just tightening it or the flare may be damaged and it wont seal anymore. Snug it up with a flare nut wrench and see what happens.
    It looks like its threaded all the way in though :/ Would require possible retubing or maybe the threads are bad, youll have to find out.
    3SNG15 Best overall
    Runs 12's (12.98's!!!!!!)
    My Garage
    Make sure the nut is tight, but I'm betting on a faulty o-ring.
    Man vs 3/S verified
    Kingston, WA
    Yeah what he says!
    Nov 2015
    Well guess I'll be trying that tomorrow! If it doesn't work, would replacing the o-ring require retubing, or are those separate fixes?
    What would those entail, if you don't mind elaborating.
    Nov 2015
    Also, what is that entire part called? I know where it connects is the " valve housing ", but what's the whole part? The oil pump? Gear box? The manual makes it seem like the gear box.
    The name of that part is the gearbox. You should be OK with just replacing the o-ring, if not you MAY need a new tube. It's been 7 years or so since I swapped racks, but I remember the o-ring being a fairly standard size.
    Nov 2015
    So I'll just use a flare nut wrench, disconnect the hose, size the o-ring, and replace, and see if that works? All there is to it?
    Also, should I be bleeding my power steering lines because of this? Any other things I should know?
    Yep, just take it apart, get a new o-ring, lube up the o-ring with some power steering fluid and install, then torque it back up.
    Yes, you'll need to bleed the lines. With the car off (and at least the front end in the air) turn the wheel back and forth lock-to-lock ~25 times, then repeat with the car running but in the air. Should be good to go from that point.
    Nov 2015
    Awesome! So, there's not a specific torque rating I need to worry about, right? Just tighten it down?
    And there's nothing I need to loosen or open when bleeding? Should I leave the cap off the resevoir?
