Hi there,
I recently purchased a 99 3000GT VR-4 which has some basic bolt-ons and is running Chromed ECU.
I have been playing with the OBD2 Inspection Monitors following the documentation on the chromedecu website and have flashed my car with several different configurations, and no matter what I do, the items which I have forced to complete still show up as incomplete.
A few things to note:
- I disconnected the battery before I did these flashes to connect a battery tender harness to plug my battery tender into this car.
- I have driven 0 miles since disconnecting the battery
- To test this, after I flash the ECU, I turn the ignition off for 15 seconds, then turn it back on and check the monitors with EvoScan.
- I also tried firing up the engine for a bit and still have the same result.
I can figure how how to post the ROM I'm trying to flash if needed. Here is a screenshot of how those things are set:
Here is the EvoScan logger output after flashing this config:
2016-03-28 19_12_48-EvoScan v2.9.0100 - CAN_OBDII_MUTII_MUTIII_OBD1_ALDL_SSMI_SSMII DataLogger -.jpg
Any ideas on why it's still not working?
