After a trip out to cars and coffee doing a little tuning I decided to try and get the trims locked in a little better then they were. After getting my injectors set I never messed with the tune anymore. The 560's are set in chrome as 450 or so to get the car to run right. Low trims where sitting about 9 so I needed to lean it out a bit at idle. I go into the Maf smoothing table and bump the 0-100 range up 2. Start the car up and let it run. I set my shop timer for 20 and just let the car run in the garage while I work on other things. I monitored it for about ten mins and I could see the low trims starting to recover and both banks get closer to within the +/- 5 range. So I went off to do some other work. I come back and now the low trims are at 12.5 both F/R. So I go back in and add more to the 0-100 VE range to try and lean it out and the trims just never recovered. Wideband is showing now the car idling in the 19-20 AFR range but the O2 Feedback is still showing 12.5 meaning the ECU is still trying to pull fuel for some reason. See logs #1 & 2
So at this point I stop and figure best to go and rescale the injectors as the ECU is still thinking the car is rich. set them up to something like 545 and set the VE table back to stock. Start the car and let it run for a bit then log the results. Same thing, Trims still stuck at 12.5 and wideband is showing 18-21 AFR. See log #3
So someone please explain this to me as what the ECU is seeing and what my WB is seeing are complete opposites. I even tried to just dial in the AFR at idle to be around 15.5-16 like it should be and after about 15 mins I come back and the ECU had adjusted the AFR to 13, trims were still all sitting at 12.5. I always wait 20 min or so between changes to see if anything is reflected in the log and seems no matter what I do the trims are stuck now at 12.5 even though the 02's cycle and the WB shows it being lean. then randomly the ECU will just upright do some stupid shit and knock the AFR all over the place. I am really starting to hate this Mitsi ECU code shit.
Files Here - https://www.dropbox.com/s/52s2s87ai0...ssues.zip?dl=1
