Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
Thread: Transmissions
    Quote Originally Posted by murphys_law View Post
    Are all the parts for the 6 speeds still available? I'm considering a swap due to 5 speed parts availability.
    The common stuff seems to be in the US with good availability. I've ordered (from cherry hill, only dealer I've used that doesn't immediately say any getrag/mitsu part # is unavailable):
    1)2nd gear, had it in under a week, was stock in atlanta.
    2)2nd gear hub slider, same thing
    3)2nd gear fork/rail assembly, same thing.
    4)Tried to order 4th gear bearing sleeve, said 60-90 days from Japan.
    5)input bearing, oem unavailable unless you go to specialist like 3sx or supercar.
    I've heard through the grapevine that reverse can be hard to get, but never tried.
    I don't have enough intel to tell you more than that.
    Feb 2014
    St Louis
    That right there is almost reason enough for me to switch. Considering I'm 5 speed that Jdm trans looks good.
    Quote Originally Posted by EmeraldRegice View Post
    I am talking about literally a complete removal of the current one, and a brand new one place on.
    You more or less can't get a brand new AWD trans for the 3/s. Best you can do as far as I know right now is go to jackstransmisions.com, pick out a build level and say you have no core or will send in later.
  4. #24
    Feb 2014
    St Louis
    Where'd you pick the Mr trans you have up from?
  5. #25
    I have bought 2. One from torontojdm on ebay and one from jdmnewyork.
    Both had broken 2nd gear hub springs that lead to a bad 2nd grind. I would never trust a used trans beyond a core value now. In fact if I was starting with nothing right now I'd just pay jacks core charge, assuming he has a six speed core in stock, I don't know.
  6. #26
    Feb 2014
    St Louis
    So basically an $800 fix to start. Ouch. Thanks.
  7. #27
    Member
    Arvada, CO
    If you want a true brand new MR trans PM duke3k as he has one he is looking to sell.
  8. #28
    Jul 2014
    March 2016
    Does it work like this: I have a 6 speed now, I will keep a 6 speed tranny, but replace gears 1-5 with the 5 speed ones, or do the gears not interchange like that in transmissions? I am in no need at the moment for parts, but plan to "stock up" on parts that may become difficult to find for the future, so which pieces of the transmission should I look for first?
  9. #29
    Feb 2014
    St Louis
    Doesn't work like that.
  10. #30
    you wouldn't want to anyway. can't even buy a new 2nd gear for the five speed anymore. Until someone starts welding new dog teeth on them they are going to start to dry up. Never been easy to find good used ones.
