Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 77
Thread: Another issue tuning with chrome
    I lack color... verified
    Aug 1998
    If it's an exhaust side leak, an intake pressure test won't show that. I may need to do my shop vac trick on the exhaust side. Set the shop vac to blow and duck tape it to the exhaust pipe. That's how I found the exhaust leaks on my car...
    I love you sometimes.
    Never finishes any verified
    Wake Forest, NC
    LOL I couldn't for the life of me find the damn leaks on my car. So I duct taped the shop vac on blow to the exhaust pipe and bam, found the two leaks I was looking for
    Check it out on Youtube!!
    Chrome ECU
    Hybrid 13g's
    EVO 560cc Injectors
    Spec Stage 3 clutch
    CX Racing Dual Core FMIC
    Megan SS Exhaust
    3rd Gen Lifters
    Maximal High flow converter
    Walbro FP & FuelLab FPR
    All -6an Lines
    AWS/ABS/Cruise Delete
    MP Rear Control Arms
    SS Brake Lines
    99 Front Conversion
    2nd gen Rear Bumper
    99 Combat Wing
    Complete interior LED Swap
    Skillard Fuel channel
    Oohnoo FPR Bracket
    More to Come......
  3. The Following User Says Thank You to DrGonzo For This Useful Post:
  4. #23
    Just throwing this out there, are you sure the fuel pressure gauge is showing correct pressure? The first one I installed was showing 52 lbs when in reality it was only 18 lbs. That really messed with my o2 output.
  5. #24
    Hudson, WI
    Is the car a CA emissions car, or Federal (look at the emission sticker under the hood)? O2 sensor pins are swapped between the two versions. If the ECU is reading the wrong O2 sensor for the bank it is trying to tune, it'll do strange crap like that. You can try periphery 0 bit 2 set to disabled to switch to single-sensor fuel trims to see if it reacts any differently. If it does, consider switching the ECU or harness to the other mode (Fed or CA).
    -Matt
    '15 Corvette Stingray Z51
    '95 3000GT Spyder VR4 (11.838@117.5)
  6. #25
    Wake Forest, NC
    Thought of that and started bumping up the fuel pressure to see if we could get the rear to cycle at all. Took it up to 60 psi and the front bank was super rich, rear never moved. FPR is also mounted on the rear rail so if it was a pressure issue, the front would not be rich as it is the furthest from the FPR.
    Quote Originally Posted by mjannusch View Post
    Sensors are not swapped Front reads front and rear reads rear on evoscan. Secondaries are removed and disabled. Running on one O2 will not work in this situation as the ECU defaults to the rear bank when you switch it to single sensor.
  7. #26
    Hmm, have you checked the injector wiring? Sure sounds like a/the rear injectors are not firing proper, and you have swapped them out so not the actual injectors.
  8. #27
    Hudson, WI
    Connect the "working" front sensor to the rear O2 connector and run in single sensor trim mode to test.
  9. #28
    Wake Forest, NC
    Bill, You're killing me here... It's not a wiring issue.
    Please re-read the entire thread before commenting.
  10. #29
    You have the original ecu? Maybe swap it in? Or swap that ecu into your car?
  11. #30
    Wake Forest, NC
    We have the original ECU but I don't think we can log to Evoscan with it. I can't remember what the exact problem was we ran into trying to log to evoscan. I'll need to check with the owner to see if he remembers.
