i went on ebay and i can no longer find the m2 exhaust system does anyone have the link or are there any other cheap systems that are good that will fit on the n/a
Go to ebay, in search type: 3000gt exhaust
Or click here:
http://www.ebay.com/sch/i.html?_from...haust&_sacat=0
About 100 hits
Now, I'm not 1000% sure that those fit an N/A 3S, but those downpipes are trash anyway.
Somebody with an N/A needs to chime in.
I'm 90% sure you can run turbo exhaust on an NA. I ran a turbo downpipe with NA catback, so that tells me that flange is in the same place. Some NA catbacks you can't run on AWD because of the rear dif. I don't see TT exhaust on an NA being an issue.
Just to open up your options..
A stock TT catback will bolt up, but a little pounding needs to be done where it goes around the rear subframe. From what I have gathered though most aftermarket TT catbacks should bolt up with no modification required.
