Anyone have any info on relocating the fuse box to the rear hatch area? All I could find on here and the other site was a mention of a couple of people that had done it, but no details on what was done or any issues they came across.
Wouldn't that add a substantial amount of weight, having to run all that wiring under the car? Unless you're building a show car, I can't see the benefit.
2013 NG: 1st place, FWD Drags
Are you referring to the underhood fuse box?
There are way better ways to hide it than to try to run it to the hatch.
Yeah, haven't quite decided on what I want to do just yet but was thinking of something that would look clean & still be functional. I've seen that the majority of people move it to the fender area, not sure if that's what I wanna do. Only reason I'm messing with it now is because I'm trying to fix the hack job done by the PO. So many wires have been cut and spliced, I'm in the process of trying to get it back to a stock & acceptable condition. Just wondering where I can improve things while I'm at it.
This was just what was under the drivers side dash and carpet. I'm hoping that once I'm done it'll clear up all the little electrical issues I keep running into.
Yep, hard to have electrical issues when you don't have any wires.
If you want it inside the car then glovebox would be a better place to put it. Hatch would add a bunch of weight + voltage drop due to length.
I've had mine relocated for about 6 months now, it is VERY time consuming. Hardest part for me was prolly learning to read the circuit diagrams. I also recently deleted the stock junction block that's on the drivers side and just added a new fuse block in the hatch. I have the wires on the passenger side running along the side and then accross the floor in the rear seat area where they meet with wires on the drivers side, then the stock fuse box and the added fuse block is back where the active exhaust unit would be.
EDIT: and yes it is a good idea to compensate for the added length and to increase the gauge of wire used. Some of the wires will actually be much longer than needed after you relocate.
EDIT #2: Next time I will prolly put the fuse blocks and relays in where the passenger airbag is though. Just need to come up with a way to remove the air bag and make some sort of bracket to still be able to bolt down the dash cover.
