Page 7 of 8 FirstFirst ... 5678 LastLast
Results 61 to 70 of 77
Thread: New MAF options coming for Chrome?
  1. #61
    Jun 2011
    Sweden, Gothenburg
    some first tings to check when running lean
    *check inlets between mas and turbos for leaks. If leak between there then you're pulling unmetered air
    *check fuel pressure (hope you have a gauge!)
  2. #62
    Oct 2011
    Sundsvall, Sweden
    Any news regarding the Jester MAF?
  3. #63
    Jan 2013
    Toronto
    Well yes and no. My car is waiting at the tuning shop and is currently scheduled for a dyno tune sometime on Weds.
    Shawzy44
    Sent from my iPad using Tapatalk
    Shawzy44
    18" Saleens, Lat42 Mud guards, TechWorks ECS controller, ECS struts w/ TEIN S springs, RetroSpec side splitters & front lip, Dejon SMIC and pipes,Jesters MAF, Mishimoto Aluminum radiator and fan shroud, Jesters Flash ECU, LCDBC w/ TFT logger, Boostmore 15G Turbos, 3SX downpipe, racepipe, 3" Quad tip exhaust, Setrab oil cooler, AEM FPR, Supra fuel pump, FIC 650 injectors, Fidanza flywhee
    Garage: http://www.3sgto.org/garage.php?do=user_garage_view&id=4247
  4. The Following User Says Thank You to Shawzy44 For This Useful Post:
  5. #64
    Jan 2013
    Toronto
    Quote Originally Posted by Shawzy44 View Post
    Shawzy44
    Here is the Dyno sheet. 407awhp, 403ft lbs.
    So this is a solid 48awhp gain from the 359awhp the car did with the 482 maf.
    Shawzy44
  6. The Following 3 Users Say Thank You to Shawzy44 For This Useful Post:
  7. #65
    Jan 2013
    Toronto
    At 17lbs the car did 379awhp with the 482 MAF so this is a solid 48awhp on my setup!
    Shawzy44
  8. #66
    What snails?
  9. #67
    Jan 2013
    Toronto
    What snails?
    Sorry edited previous posts above... it was 48awhp gain not 28awhp. Using Boostmore 15g turbos with the standard wheel.
    Shawzy44
  10. #68
    Jun 2011
    Sweden, Gothenburg
    This gain with all other parts except maf being the same from run to run?
    Gain seems a bit too much. From all I've read evo maf is not a limitation at those hp levels..
  11. The Following User Says Thank You to Ange For This Useful Post:
  12. #69
    They're literally a combo of a stock 3/S MAF housing with EVO MAF internals. It's been tested to make well over 450hp so far but no one seems to have a car capable of making any more power than that. That's why we haven't really been advertising it. It hasn't been tested on a car making any real power.
    Interesting.
    I have done a bunch of work understanding how the MAF plays with the AEM EMS http://farnorthracing.com/stealth/AEM_Mitsu_MAF.html and I've been laying the groundwork for conversion to speed/density via locating a combo MAP/AIT sensor on the manifold http://farnorthracing.com/stealth/MAP_sensor2.html
    But the MAF is really soooo easy to program.
    Has anybody ever dropped one of these things on a flowbench and measured CFM cs MAF freq directly?
  13. #70
    Jan 2013
    Toronto
    We don't have any specific evidence that the new MAF instantly delivered the extra HP. It was not a comparison dyno only session. This was a tuning session with the new Jester MAF installed.
    There are likely other factors at play here that contribute to the gains. Not the least of which is the runs (as seen in the dyno sheets) did NOT occur on the same day.
    I would suggest that this is comparison has some room for error when looking at just the new MAF. But what the data does tell us is that the MAF is a good choice for standard 15g turbos (vs say a MAF-T and GM MAF setup) and not a limiting factor in HP at this level (which we expected).
