Page 1 of 6 123 ... LastLast
Results 1 to 10 of 54
Thread: Cool stuff!
    Mar 2013
    SL owner since Jan 2010. VR4 owner since Sep 2012
    Riverside, Cali
    Cool stuff!
    For sale. PM me or text at (951) 258-6161 if you more info/pics. Quick response. MOST shipping prices included.
    *SUPER RARE* Genuine ARC Magic radiator cap. This is a Type B so unfortunately it doesn't fit 3S's. Will for various other Japanese cars tho. PM me for details on fitment- $60 shipped
    *NEW and RARE Veilside license plate frame- $25 shipped
    *NEW and RARE DS Bride type FO seat rail SPECIFICALLY made for 3S's. 2 month wait from Japan. Its only for bucket seats and they fit various brands (semi universal-ish). PM me for more details- $100 plus shipping .
    *NEW and RARE Pit Road M 2015-2016 catalog- $20 shipped
    *NEW and RARE Pit Road M 2014-2015 catalog- $20 shipped
    *NEW and RARE (for the Honda/Acura bois) late 90s/early 00s DC Sports license plate frame x5- $20 shipped ea
    *NEW OEM rear main seal- $30 shipped
    *NEW OEM front cover to lower intake mani PCV hose- $18 shipped
    *NEW OEM FWD manual gearshift oil seal AND new OEM shift lever boot. Selling as pair- $20 shipped
    *NEW Morimoto "XChange" switchback drivers (x2)- $30 shipped for both
    *NEW universal 50mm gauge pod for dash- $15 shipped
    *NEW non oem Rear Sway Bar End Link DOHC from Ninja- $20 shipped
    *NEW Earls Plumbing 900110ERL (AN -10) (x2) AND 900106ERL (AN -6) (x1) Econ-O-Fit Hose Clamps in red- $20 shipped for all 3.
    *NEW OEM PS 1G 3000GT turn signal tab- $6 shipped
    *NEW horn kit for various quick release steering wheels- $15 shipped
    *NEW non oem oil return gaskets made of composite (x6)- $6 shipped for all
    *NEW 3in 45 degree coupler and used 3in degree coupler- $15 shipped for both
    *NEW National trans output shaft (?) oil seal (x2). PN: 223543- $15 shipped for both
    *NEW Set of New Black Rubber Tire Wheel TR413 Valve Stems with Chrome Caps- $13 shipped or add $5 to any order
    *NEW pair of universal side splitters. 82.5"x3.5" EXCEPT for one that i cut about 4in. Long enough for most cars- $25 PICK UP ONLY
    *NEW AN6 oil hose separators in red (x2)- $13 shipped or Add $5 to any order to get both
    *NEW universal bumper lip- $13 shipped
    *NEW Autozone/Duralast slave cylinder- $20 shipped
    *Stock oil cooler from a none spun bearing car- $20 plus shipping.
    *Custom catch tank. No lines- $40 shipped
    *Door triangle pair. No cracks- $20 shipped
    *Door triangle pair. PS is cracked a lil- $11 shipped
    *Recirc adapter for HKS BOVs- $15 shipped
    *PS 1G 3000GT headlight bezel. Top portion- $15 shipped
    *PTU bracket- $16 shipped
    *Plastic adapter for aftermarket air filter- $15 shipped
    *Pair of red a-pillar sills. Has come clear coat coming off on the DS- $25 plus shipping
    *EVAP plastic connector thing thats NOT broken- $20 shipped
    *Radio brackets- $15 shipped
    *Crank angle sensor 93+- $15 shipped
    *1G brackets for snake eyes- $35 shipped
    *Rear view mirror- $13 shipped
    *Pair of fiji blue side mirrors. Clear coming off- $20 plus shipping
    *PS 1G fiji blue headlight cover- $20 shipped
    *Pair of 1G side front bumper brackets. They go on the very bottem- $10 plus shipping
    *Crank position sensor- $15 shipped
    *Double din bezel- $15 shipped
    *Pair of wastegates- $35 shipped
    *Rear wastegate- $20 shipped
    *Decent non-padded PS upper door insert- $15 shipped
    *Injector resistor bracket- $15 shipped
    *Okayish driver side 2G 3000gt side skirt in red. Cracked in 2 places but not very visible- $10 (pick up only!)
    *Thermostat cover- $15 shipped
    *Unknown brand used NA clutch- Bought it from Aaron (widebodyvr4) but got something else instead. Supposedly has less then 10k miles. Sold AS IS- $30 shipped.
    *Working 1st gen airbag- $20 shipped
    *Window washer fluid tank (x2) WITHOUT pump- $10 each plus shipping
    *Used pair of radiator hoses- $10 plus shipping
    *2 rear trunk cubby covers (ask for a pic)- $15 shipped
    *OEM radiator brackets (x3 sets)- $15 shipped each set
    *Aluminum shift knob- $15 shipped
    *Main fuse box cover- $20 shipped
    *Turn signal switch for a Nissan Pathfinder- $15 shipped
    *Custom radiator/FMIC under car air scoop? Came out of a 1G Stealth. I've heard its rare? -Throw me an offer
    *91-98 red sail panels (only the "colored") part- $25 shipped
    *ABS relay- $15 shipped
    *Headlight, horn, ignition relay- $15 shipped
    *FS fuel rail- $15 shipped
    *Front pre-turbo pipe WITH insert- $20 shipped
    *Various sized couplers (x8; mostly blue)- $25 shipped
    *Interior fuse modulator with fuses. I think its for a 2G VR4?- $15 shipped
    *Custom aluminum T piping to connect to BOV- $15 shipped
    *Foglight/headlight (1G) switch- $15 shipped
    *Interior triangle plastics (x2) that go by the door- $15 shipped each set
    *DS locking/sliding window switch- $20 shipped
    *Clips (x6) that hold the glass/lexan to headlights- $6 shipped for all
    *Decent housing to turbo gasket- Add $3 to anything you order and its yours
    *Motorad thermostats (x2)- $15 shipped each
    *Amazon Firestick. 1st gen. Its jail broken but needs to be updated. All features work properly tho- $20 shipped
    --->Open to trades/partial trades. Looking for 2 piece 5 speed aluminum driveshaft, Greddy EMU, some interior parts, new W/M AEM kit, new oil cooler, and new OEM stuff.
    1991 Monza Red VR4- Weekend ride: Tanabe Super Medallion Hyper exhaust, 0.8 bar WGs, Turbosmart MBC (@1 bar), 3SX turbo pre-pipes, Straight pipe, Greddy Type RS BOV, Godspeed FMIC w/ PPE pipes, Stillin DP, HKS duel filters, RPS stage 2 clutch, 3sx SS clutch line, Custom oil catch can w/ braided lines, Krank vents, Ohhnoo's fuel loop, HW fuel pump, PC'd 2G brake swap w/3sx SS lines, Hawk pads, and Stop Tech rotors; Various deletes, PC'd/polished engine stuff, Koyo rad, Greddy coolant cap, DBest custom oil cap, Pit Road M front strut bar, PRM plug cover, PRM tailights, PRM CF Falcon hood and PRM shift knob, Morgan Motorsports splitter, 19x8.5 +27/19x9.5 +24 Volk GT-Cs wrapped Nitto NT555s, 99' bumper conversion, 99' sail panels, 2G side skirts, Retrofitted 5G Celica mirrors, Retro Spec side splitters, RS rain guards, and RS rear window visor, factory GTO light up visors, Custom fit Top Secret style diffuser for 350z, Robo mod w/halos, 3G rear garnish, Momo steering wheel, Tein Street Flex coilovers, 3SX control arms, Apexi turbo timer, Apexi mechanical boost gauge, Zoom Engineering Penta rear view mirror, Veilside navigators foot rest, Pioneer HU
    VR-3747 :D Not Verified
    Dayton Ohio
    What color are the lug nuts?
    Mar 2013
    Riverside, Cali
    They're black.
    Dec 2014
    Dearborn
    how much shipped to 48150(commercial)? any damage at all ? please send me pics to 313-378-0034
    Thanks,
    Patrick
    STL, MO
    15 for the ecs caps?
    1991 Stealth RT/TT
    Mar 2013
    Riverside, Cali
    I can do that shipped. Heres a pic. LMK if you're still interested.
    Mar 2013
    Riverside, Cali
    bumpieeo
    Mar 2013
    Riverside, Cali
    bummppppp
    Aug 2015
    Do you have a picture of the charge speed lip?
    Mar 2013
    Riverside, Cali
    bump! Updated the list!
