Results 1 to 2 of 2
Thread: Help with Degreeing GZP Preset Cam Gears
    I purchased some DR stage 3 heads that were decked (and who knows if for the first time in their lives) and I'm planning to degree with my GZP Preset Cam Gears to see how close they now are to their preset +1,-3 and whether they are far enough off to justify a change to adjustable cam gears.
    My very basic (perhaps stupid) question is: are the +1,-3 degrees everyone uses degrees of cam or degrees of crank (=2x degrees of cam)? In other words, with stock settings for lobe centerline of 109.5 degrees intake and 106.5 degrees exhaust should I be looking for centerlines on the preset cams of 110.5 / 103.5 (if the +1,-3 are degrees of crank) or of 111.5 / 100.5 (if the +1,-3 are degrees of cam and x2 for degrees of crank)?
    '95 Spyder VR4:
    Exterior/Suspension: '99Front End/Rear Garnish; 19x9 370Z forged Rays Eng wheels; CF 575 Hood; Tein S tech (front) and H tech (rear) springs with rear adjustable control arms; Adjustable Front Tein Pillow Ball Mounts.
    Interior: Hella TPMS; LCDBC; Remote Top; Interior Rearview Mirror with Temp/Compass/HomeLink.
    Brakes: DBA 4000 Slotted Rotors - HPS Pads - SS brake lines.
    Performance: Pampena Bell-housing reinforcement; Pampena pistons; Ninja Lightweight Rods; Dynamic Racing Stage 3 heads and Billet DR650s w/9 Blade turbine and Billet actuators; ported I/E manifolds; DSM SMICs; ID1000s; Flashable ECU ('98) - Chrome 2.0; GM 85mm MAF & translator; 3SX Downpipe; IPS Quad tip exhaust; Walbro 450LPH E-85 fuel pump; K&N fuel filter; AEM AFPR; ACT pressure plate MB019; Maximal/Setrab Oil Cooler; 3SX high capacity radiator; 3SX adjustable cam gears; 3SX Poly mounts; HKS Twin Power.
    Medford OR
    Cam degrees.
