Ok today i installed a "Jester Chrome ECU" i bought from 3SX, an AEM TRU Boost and an AEM WideBand. I then flashed the chrome V2 stock rom with the disabled peripheries recommended in the tuning thread here in the forum. The car starts fine and idles fine initially but after a bit it starts to idle a bit funky. Idle drops and vibration goes way up. Then when i try to drive the car under low to medium load let's say anything from 10-70% throttle the car runs like crap the Wideband is pegged lean if i hold the throttle there for a bit and let the rpm come up as i gain speed suddenly the car "jumps" into power/boost (almost like flipping a switch) and runs fine until i let off the gas and do it all over again. Additionally it seems that if i go WOT the condition clears up and the car runs ok, but ONLY while i am at WOT or close to it say anywhere above 80-85% throttle.
The car is basically just a BPU car. It has: No cats, 3" DP, K&N Intake CX Racing Dual Core FMIC, HKS SSQV 4 BOV (Open to atmosphere). Full Vac Reduction, Stock Fuel stock Turbos. The car runs PERFECTLY with this same exact setup on the Stock ECU. The only things that changed were the Chromed ECu and the Boost controller. ( i was running a Blackstealth LCDBC and switched to the AEM TRU BOOST)
Any ideas?
