Now available are 3 port boost solenoids that are plug and play. These come in 2 different varieties. One for use with the factory solenoid cluster (comes with a mating 2 pin plug). And one for those that have done a complete vacuum delete (currently for 91-97 models, 98-99 models coming soon) and have rid themselves of the factory solenoid cluster (comes with a mating 6 pin plug). These are a great item to add to your Chrome ecu, or to an EMS setup that supports a 12v solenoid. The setup also comes with vacuum tee for the wastegate actuators, vacuum line, mounting bracket and hardware, and 90 degree fittings for the solenoid to allow for a compact install.
https://3swarehouse.com/product/plug...oost-solenoid/
