http://imgur.com/a/CJ9vA
1995 Black VR-4 502awhp (Dynojet) and 425awhp (Mustang) at 13PSI pump gas
I have decided to sell my vr-4 after owning it for about 6 years. The car has always been a non-daily garage kept car(even the previous owner). Some life changes have made me make the decision to sell. I don't really need to sell it, but I only drove the car about 100 miles this whole year. It just sits around and I don't really have the time for it anymore.
A little about the car. The chassis has 136k. The rebuilt engine and new turbos have approximately 29k miles. The car should be capable of 600+ hp. I never had time to put a race gas tune on it or E-85. The last time I had it tuned at IPS apparently the DLI went bad and ran into spark blowout at 13 psi. So the car will need a new DLI. The previous owner had the car to 57x on 114 at 19 psi.
I have taken very good care of the car and drive it like a complete grandma 99% of the time. The interior is in great shape (new carpet). Exterior is original and has chips and scrapes here and there (mainly front bumper). It is a 20 year old car and has some issues. I will list everything I know thats wrong here. DLI is apparently bad (I dont know how to test it). AC isnt working, it apparently has a slow leak. I never used it so I never cared to fix it. Front strut mounts need replaced, I have new ones and will come with the car. Rear wiper doesn't work (never needed it). Active areo works sporadically. Second and third gear syncros arent perfect. The car shifts perfect at high rpms, but if your shifting lower rmps into second or third, you just have to be easy. There is no spare tire or jack due to the custom hatch area for the nitrous and battery set up. The nitrous bottle has been disconnected ( I never wanted to use it) but everything is wired and plumbed for it.. I will sell the bottle and everything with the car. It just needs to be hooked back up. The crank thing for the sunroof is striped out and doesn't work. I'm probably just being nit picky about a lot of this I just don't intend any surprises.
$11000 firm at this time. I'm in no hurry to sell the car and might just keep it if I cant get what I want.
BOTTOM END
Machined and micro polished crank
Crower Rods
Wiseco Pistons w/ relief cuts
Federal Mogul Rings
Bored, honed and polished block (.030)
TOP END
3KGT Motorsports Stage III w/1mm oversized Ferra Valves
5 Angle valve job, full port and polish
99 Lifters
IPS Steet Cams (272) w/high rev spring and titanium retainers
VSS done about 5k miles ago
EXTERNAL
IPS TDO5 ceramic coated manifolds
MHI EVO III 16G turbos
Custom AAM front mount intercooler w/ piping
Custom AAM dual intake piping
Custom AAM dual APEXi’ N1 exhaust system
HKS Dual Intakes w/ filters
Dual HKS SSQV blow off valves
3SX Performance Lightened flywheel pulley
IPS Oil Cooler (Setrab)
IGNITION
Magnecor 8.5mm plug wires
HKS Twin Power DLI (bad)
New coil pack
New PTU
FUEL SYSTEM
PTE 780cc Fuel injectors
Denso Supra Pump
Kenne Belle BAP
ELETRONICS
AEM Engine Management System
AEM 3.5 Bar MAP Sensor
AEM Single Channel UEGO Wideband O2 Sensor
GM IAT Sensor
AEM Serial Gauge (Set to display coolant temp or Wideband readings)
AEM Electronic Fuel Pressure Gauge
AEM Electronic Oil Pressure Gauge
Apexi EL2 Kpa Boost Gauge
Apexi EL2 EGT Gauge (Rear bank)
Apexi EL2 Controller Unit
Full Indigo 6 color stock gauge replacement
HKS EVC IV Boost Controller
Viper 550 ESP alarm system
PIIA 1100 Series Fog Lights
PIAA 9000 Series Headlights w/HID Relay System
Blitz Dual TT DC II Turbo Timer
DRIVETRAIN, BRAKES, WHEELS, ETC…
Kormex 6 speed transmission
ACPT carbon fiber drive shaft (one piece)
3KGT short shifter
Stillen Motorsports brake rotors on rear
Eibach Ground Control Lowering System
19 x 8.5 SSR GT-7 wheels
Nitto 555 245/35/zr19 tires
3sx rear adjustable control arms
New front strut mounts (not installed)
BODY
99 front-end conversion
99 headlights
99 turn signals
MISCELLANEOUS
Nitrous Express Wet Nitrous system (Disconnected at this time)
Nitrous Express purge valve, bottle warmer, remote bottle opener
Sony CD/mp3 unit with USB, Ipod sync and audio input
10" Fosgate woofer, Polk audio speakers
Two Sony amps
120k service done at 110k
Start up vid
