RIP Lemmy!
I was fortunate enough to attend a Motörhead show 3 times in my life. Absolutely awesome!
A truly GREAT band with one of the best front men in the business.
You'll be missed by millions.
Oh, no, not Lemmy.
RIP Ace of Spades...![]()
RIP
