As some of you know I have done a TT conversion to my white car. That was followed by an AWD conversion, and then later a 3.5L swap. One of the most asked questions I see on the forum (and especially FB pages) is "how hard is it to TT/AWD convert these cars?" Usually the answers range from "Pain in the ass, if you have to ask, you probably shouldn't attempt it", "you can do if you really believe you want to", or "Just buy a VR4".
So this is my thread about my build that is already beginning as a TT car. I originally picked it up with bent valves and intentions of just fixing and flipping it. I've since decided I'd like to do a mild build with it. Something that I can DD if I want but still makes enough power to dispatch a modern Camry. Nothing crazy like powder coating, just going to use spray paint, mostly. Exterior will be painted correctly of course.
This particular car presents its own set of challenges. It has sat for about 15 years. The previous owner put it up on blocks, and wrapped it up under a tarp under his carport behind his garage. It has a fair amount of surface rust underneath, and by "fair amount" I mean it is completely surface rust. I'm actually somewhat looking for a cleaner shell to use, but this is what I have, so I'm going to try to make the best of it. I'm also trying to keep the budget (without paint) around ~6k.
It's a green (for now) 92 RT/TT with 109k, charcoal interior, no sunroof.
Build plans:
Engine:
15g turbos
FIC 650s
Jackhammer gears
fuel loop
Maft (blow through)
Wally 450 (e85)
e85
xtd stage 2 clutch
SS downpipe
Gutted rear precat
??Exhaust?? – undecided
Ninja T-Case brace
Exterior:
B5 Blue
Engine bay painted black
Black Kazera wheels
Retrospec lip and side splitters
2g stealth rear bumper
??wing?? - undecided
Suspension.
Lowering springs with stock ECS struts
AWS delete
Rear sway bar
Adjustable upper ctrl arms
Two piece steel/AL driveshaft
ABS delete
The day I brought it home:
The stock wheels and tires didn't hold air, and since I was still planning on selling it I picked up some super light WEDS Sport wheels.
Started by pulling the heads to assess damage.
Lots of cleaning and painting parts.
Got the 15gs from TimP (Boostmore) and adjusted the wastegates.
New hoses, plugs, wires, timing belt, tensioner, etc, etc, etc
