Results 1 to 8 of 8
Thread: Help Please
    Memphis
    Help Please
    Needing the white plastic cap with 2 male ends for the radiator reservoir/overflow tank
    Any suggestions on were to purchase such an item will be appreciated
    Feb 2014
    2002 and 2014
    Hamilton, Ontario, Canada
    Replace the whole tank. They are cheap.
    Memphis
    Quote Originally Posted by sohcstealth View Post
    Thank You! Didn't even think of that. Do you have a part number for the whole assembly/tank?
    Feb 2014
    2002 and 2014
    I don't. But they can be purchased through Ninja Performance/3sx or any other 3/S vendor.
    Memphis
    Thank You. I've tried contacting (thread bump+email) the very first parts sponsor on this sites approved list (3000gt/stealth supply?) but haven't anything back from them. Also, looks like their website is no longer in service?
    Do you have a web address, email or phone # for this Ninja fellow you speak of?
    Memphis
    Looks like the cap & recovery tank are 2 seperate items if bought/found new?
    RECOVERY TANK for 1994 Dodge Stealth|MB605465
    Medford OR
    Memphis
    Thank You. Just talked with John @ Dodge. He had nothing, but was kind enough to send me across the street were Mike @ MITSUBISHI was able to seal the deal
    Thank You both for the assistance!
    I have another question I will post tonite!!! haha
