Results 1 to 4 of 4
Thread: ::WINNER:: October Car of the Month :: FeaRpb
    Congratulations to FeaRpb & their
    1992 MITSUBISHI 3000GT VR4
    FeaRpb's Garage Link
    Long story short. I picked this car up back in 2007 from an elderly lady. It had 8x,xxx miles on it when I bought it from her. I tore it all apart at 11x,xxx miles to build a td04 monster.
    Here is my current list of mods which I am sure is missing something.
    Built Pampena 3.1 6g72 w/ rays custom ross pistons with upgraded pins - oliver billet rods - new OEM forged crank
    Pampena 5 speed with 300m 25spline OS
    Clutchmasters 850 series (8.5'') Stage7/8 - 2 Lightweight Unsprung Race Disks
    Broomfield Racing Billet Transfercase
    Port and Polished Heads - Pinned - +1mm exhaust valves and GZP +1 and -3 degree cam gears
    GCTech Tubular td04 front & rear manifolds + rear o2 housing with Ceramic Coating
    Dynamic Racing DR-750r turbos
    STM tank to rail fuel kit
    HKS Twin Power
    Apexi S-ITC
    ABS Delete
    Austin@STM's Front hubs w/ ABS Sensor delete
    Austin@STM's Driver side intake manifold.
    Austin@STM's old stripped down VIS Carbon Fiber hood
    Austin@STM's Half size koyo race radiator
    Bought about $2400 in OEM parts to make this whole long block build fresh (Thanks Chris)
    DR ARC-2 w/ 92mm MAS
    BlackStealths LCD Boost Controller w/ MAC Valve
    Greddy SMI Boost/Water Temp/Oil Pressure Gauge w/ controller
    Deatschwerks Injectors 1000CC Injectors
    Walbro 400lph E85 Pump
    Treadstone TR1235 Intercooler w/ Custom Hard piping Thanks to Dave@Pampena
    Megan Coil Overs
    Corbeau Forza Sports
    Maximal Adjustable Control Arms
    STM Standard Oil Cooler
    Maximal Solid Mounts
    David's Replacement Trans Mount
    Ninja Performance IAC Block
    Pampena Billet Rear Diff Bushings
    TiAL Q BOV
    Pampena AWS Delete
    Austin@STM's VIS CF Hatch
    Solid Rear Diff Bushings
    Krank Vents
    Street/Strip Cage
    AX6 Front & Bobcat Rears w/ Power Slot Rotors - Brakes
    CFDS
    Aftermarket Radiator w/ pipes
    Very short exhaust
    I should really update my pictures...
    Easiest way to win is to be the only entry.
    SUCCESS!
    I would have voted for you had you not been the only one.
    < a little homo
    Thanks babe!
    Sent from my SAMSUNG-SM-G920A using Tapatalk
