Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: White/Black
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Under Passenger Seat (Optional Item)
Car Audio Dash Speaker Size: 3 1/4"
Left Dash Speaker Positive Wire (+): Orange/Blue Stripe (Pin 13)
Left Dash Speaker Negative Wire (-): Brown/Blue Stripe (Pin 14)
Right Dash Speaker Positive Wire (+): Orange/Red Stripe (Pin 3)
Right Dash Speaker Negative Wire (-): Brown/Red Stripe (Pin 4)
Car Audio Door Speakers Size: 6 1/2″
Left Door Speaker Positive Wire (+): White/Blue Stripe (Pin 5)
Left Door Speaker Negative Wire (-): Black/Blue Stripe (Pin 6)
Right Door Speaker Positive Wire (+): White/Red Stripe (Pin 15)
Right Door Speaker Negative Wire (-): Black/Red Stripe (Pin 16)
Car Audio Rear Speakers Size: 6″ x 9″
Left Rear Speaker Positive Wire (+): Yellow/Blue Stripe (Pin 17)
Left Rear Speaker Negative Wire (-): Gray/Blue Stripe (Pin 18)
Right Rear Speaker Positive Wire (+): Yellow/Red Stripe (Pin 7)
Right Rear Speaker Negative Wire (-): Gray/Red Stripe (Pin 8)
Can anyone confirm the Dash Speaker wires are correct? Or is that the color of the wires on the speaker ends? I ask because I have read that off the amplifier the door and dash speaker wires are the same colors, just that the door wires are a heavier gauge.
